Question about Amana SXD524VW Side by Side Refrigerator
Amana sxs sxd26vw refrigerator cools and freezes intermittantly
My fridge doesn't cool or freeze consistantly...ice melts, not cold soda, etc. I can hear the fan below running when not cooling and when I turn the cool and freeze controls, the fan will shut off. I have vacuumed the TOP of the coils, but the bottom is seemingly unaccessible. I believe the coil is fastened to the chassis. would it be worthwhile to pull unit from wall and lie it on its back to maybe get at the bottom of coil? or am I totally on wrong track? (the top of the coil was extremely dirty with cat hair and such, so I'm thinking bottom can't help but be... cutting off airflow? the times that the unit works it cools & freezes very well since I cleaned top. Any ideas? THANKS!
  • 3 more comments
  • jjmac365 Dec 15, 2008
    my fridge doesn't cool or freeze consistantly...ice melts, not cold soda, etc. IT DOES RUN OK ABOUT 95% OF THE TIME... I can hear the fan below running when not cooling and when I turn the cool and freeze controls, the fan will shut off. I have vacuumed the TOP of the coils, but the bottom is seemingly unaccessible. I believe the coil is fastened to the chassis. would it be worthwhile to pull unit from wall and lie it on its back to maybe get at the bottom of coil? or am I totally on wrong track? (the top of the coil was extremely dirty with cat hair and such, so I'm thinking bottom can't help but be... cutting off airflow? the times that the unit works it cools & freezes very well since I cleaned top. Any ideas? THANKS!
  • jjmac365 Dec 16, 2008
    Additionally, I notice that the freezer coil in the back of the freezer compartment builds up considerable frost over a few hours. Then it goes into the defrost cycle and almost entirely melts. It is during this period that the refrigerator gets not cool too. Almost like the cycle lasts too long....
  • jjmac365 Dec 17, 2008
    my fridge doesn't cool or freeze consistantly...ice melts, not cold soda, etc. IT DOES RUN OK ABOUT 95% OF THE TIME... I can hear the fan below running when not cooling and when I turn the cool and freeze controls, the fan will shut off. I have vacuumed the TOP of the coils, the times that the unit works it cools & freezes very well since I cleaned top.
    Additionally, I removed the cover in the back of the freezer compartment and I noticed that the coil in the back of the freezer builds up considerable frost over a few hours. When I turn the timer screw a couple clicks,it goes into the defrost cycle and entirely melts. It is during this period that the refrigerator gets warm, too. Almost like the cycle lasts too long B4 it turns back on & everything is fine for awhile....
    ok, then. how's the best way to get to the bottom of the coil mounted on the base???
    puerkoness, does the fact that the unit cools and freezes very nicely most of the time indicate anything?
    Genius:
  • 1,199 Answers
The bi metal switch (thermastat needs replaced!
Posted on Dec 17, 2008
  • 2,427 Answers
It just needs gasing, have a local ac / refridgeation guy just come over and fill it up. The gas is top expensive to buyt it to do it your self plus you will have a lot left over. Have him check for a leak while he is there. But you problem, is the fridge is running short on gas.
    Top Expert:
  • Amana Master
  • 77,499 Answers
Replace the defrost time. this is the most common fault
  • Amana Master
  • 8,220 Answers
You want the whole coil cleaned on bottom. Check your defrost heater. Clear your defrost drain. One last thing. Your compressor relay may be getting intermittant. Over time they tend to start to fall apart. When an ice box starts doing like yours is I always check the relay. Remove it from the compressor and give it a shake. Take a look at it.
  • Dan Webster
    Dan Webster Dec 17, 2008
    Water is pooling up under the crispers: defrost drain is stopped
    up. When the ice box defrosts the water has to go somewhere. If the
    drain is stopped up then it will cascade down the rear walls of the ice
    box and pool up under the crispers. Solution? Clear the drain using hot
    water, hair dryer, shop air, remove the object blocking the drain. Door
    gaskets that are worn or broken will allow for air to get into the ice
    box and excessive moisture will build up.
    Freezer is frosting up, fresh food section is warm: bad fan motor,
    defrost drain stopped up and forming slab of ice between the freezer
    and the fresh food section. Solution: check heaters and
    terminator(defrost thermostat) unplug the ice box and let it defrost
    completely. Clear objects from drain. Check timer. Note to find the
    location of your timer look up your model number online.
    Refrigerator dead: it may be that the defrost timer has went into
    defrost and got hung up there. Twist the timer around several times and
    it may start working till you can get another.
    Refrigerator runs all the time: The thermostat is fried (internal contacts stuck together) replace it.
    Compressor won't run: burned up relay. Remove the relay from the
    compressor and shake it. If small particles come out or it sounds like
    a salt shaker or there is no sound at all or it smells and looks burned
    then it is bad. Replace it.
    Freezer getting warmer freshfood not cool at all: Check under the
    bottom for the fan motor to be running and the cob webs, dust, dirt,
    and pet hair, off the condenser coils. If the fan underneath has quit
    then the ice box won't get cold.
    Everything is freezing over in the bottom and the top. Bad cold control.
    Do I need freon? 99% of the time NO. Most of the time it is a
    dirty coils problem or a bad fan motor, unless you have a leak. Since
    the ice box only holds 4 ounces of freon it would quit cooling at all
    in a short time if it had a leak.Their would be no halfway cooling, not
    for long anyway.
  • 275 Answers
Two things that you might want to check for is first if the compressor still works
second: if the refrigerator still has freon .
  • 3,037 Answers
Well if there's hair then the lack of airflow sounds like the problem.
Defrost the freezer totally, clean everything really good and let it dry.
Let me know how it works after doing this. As long as the fan is working, it should be staying a constant cool temperature.
bestdarngood
Posted on Dec 15, 2008
  • Benjamin Patri
    Benjamin Patri Dec 17, 2008
    Tune down the defrost cycle, Unplug the unit, clean it, and dry it out and make sure it is sealing well. If it is icing up, then you may have a bad seal on the door which would need to be replaced and will explain the problem that you are experiencing.
    Genius:
  • 1,061 Answers
Have refrigeration system(freon)checked for leaks and proper level.RICHARDM69
    Master:
  • 479 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
    ooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
    Evaporator coils
    Condenser
    Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
    Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
    The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
    Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
    • The defrost timer
    • The defrost thermostat (also called the bi-metal switch)
    • The defrost heater
    If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
    Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Sep 17, 2013 | Freezers
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
Refrigerator/freezer stopped cooling/freezing yesterday. Lights are on inside and 8 hear the fan running in the freezer but no cold air. Tried powering off and also unplugging to see if it would reset...
possible failure of defrost mechanism causing ice to build up behind back of freezer preventing air flow into freezer and fridge. Try turning it off for enough time for ice to melt if cause.
if this is issue the repair man will need the ice half melted to be able to test the thermistor that senses the ice buildup.
Nov 06, 2017 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Amana SXD524VW Side by Side Refrigerator Logo
139 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
