Bought a display kitchen with a neff double oven and it dos not work electric is connected and switch lights show ovens should be on but nothing works
    Problem Solver:
  • 8 Answers
It's very possible that you only have half the electricity needed the lights will come with 110v but not the oven so check to make sure you have 220v's also there may be a inline fuse that may be blown but you have to do some searching to find it probably behind the panel on the back side of the oven kill power before looking
Posted on Dec 15, 2008
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Display on top electric oven
The oven is locked by childproof lock.
Rotate anticlockwise the function selector 3 times from the 0 position to the light bulb.
Oven light –5– goes out.
Jul 08, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
