Question about Matrix HANNSFREE 19 Analog and Digital Widescreen Active TFT LCD Display HW-191D Monitor
Hanns-G HW-191D 19" Widescreen TFT LCD Monitor
I just purchased this monitor and I cannot get it into VGA mode using the monitors menu. I'm stuck in DOS (type or graphic). The little VGA icon doesn't lite up and the cursor just skips over it. My pic's suck, theres no 3D and I don't want to send it back but if this is a defect I will. Does anybody know anything about this problem?
0 characters
1 Points
I have a hanns g hg281d just over a year old. It has started blinking on and off several times when it comes out of sleep mode in the am. Is the power supply going bad? I have talked to other people having...
your monitors pwr supply has been worn down, you need a new one (most just get a new monitor) in order to avoid this problem in the future, make sure the screen is placed in a vell ventilated area, and that you turn the power off every once in a while.
Sep 26, 2010 | Hanns.G Corporation 27.5" Widescreen...
Can Mac OS10.6 snow leopard support HW 191or is there a driver available
Monitors rarely have drivers, aside from color profiles. It is the computer itself which is responsible for feeding standard data to the monitor and as a result any monitor which accepts the correct input (VGA, DVI etc) should work fine.
Due to the monitor only being 19 inches, you will not have any complications regarding different specification DVI, so I need not go into it.
Oct 30, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Sreen shrunk a bit and now cant chanage it to normal
Control Panel->System->Hardware->Device Manager. Select Display Adapters and uninstall it. Then Ask Windows to scan for new HW. Let it detect and install the display adapter. If this does not work then select Monitor and uninstall it. Make Windows detect the monitor and install it.
Aug 23, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
LCD Monitor takes time to display HANNS.G Model
there is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
May 22, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
I hope that helps
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Matrix HANNSFREE 19 Analog and Digital Widescreen Active TFT LCD Display HW-191D Monitor Logo
27 people viewed this question
Top Matrix Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Matrix Computer Monitor Expert? Answer questions, earn points and help others
