Question about Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
Oil level check
6.5 hp, 80 gal colman
parts book lists modle no. as L6506016
do you check the oil level with the dip stick screwed in or not screwed in?
answer to ken
  • 21 Answers
Chack oil mwith the dipstick unscrewed.also if yours has a site glass be sure the oil level is in the center of the glass
Posted on Dec 26, 2008
How much oil do I put in my car 19 00 cc
1. Turn off engine ,
2. Take of oil cap on engine
3. Put in a little oil in oil filler hole of engine.
4. then pull out the oil dip stick from engine
5. and clean the dip stick on a rag.
6. Put dip stick back in engine
7. pull out again and check the level showing on the dip Stick
8. If level is too low on dip stick and is not at full level go back to step 1
These steps ensures you avoid over filling the engine with oil
Tip for beginners
The 4 litre oil bottle is way too much oil for an engine to handle.
If you have a full 4 litre oil plastic bottle square shape . hold the bottle on its side to pour the oil out slowly and smoothly.
Jun 04, 2016 | 2005 Mitsubishi Carisma 1.6
How to tell the motor oil is filled on the dip stick
The dip stick has markings on it showing the level it should be at.
Jan 04, 2016 | 1997 Cadillac Eldorado
On a 1973 Ariens Snowblower with a 7hp Tecumseh motor what is the proper way to check oil level? Do you screw the dip stick all the way in or let it sit on top of the oil fill hole?
To check the oil you screw the dip stick as far as it will go. Before you start take the stick out and wipe it off then insert and screw it in to the bottom then take it out and check it.
Jan 26, 2015 | Garden
How much oil does a husqvarna 224l use
The manual does not call for a specific volume of oil. Make sure to check the level using the dip stick and make sure the oil level is approximately half way up the dip stick. If oil is needed, SAE10W40 is recommended.
Sep 01, 2014 | Husqvarna 224l Gas Powered Line Trimmer, 4...
Help please
There is a dip stick screwed into a tube on the side of the crank case or a screw plug directly into the crank near the bottom (normally coloured red) If it is a screw plug then unscrew and correct oil level is near top of thread Replace plug when finished. If it is a dip stick remove the dip stick--- wipe clean ---and replace screwing it all the way I. Remove again and check oil position on dip stick Should be on top mark or top hole if there are holes.
Apr 26, 2013 | Cell Phones
How much oil and what kind 1982 yamaha vision
It will take about 2 quarts. Don't you have a owners manual with your motorcycle?
Drain the oil, replace the plug, add one quart. check the dip stick, slowly continue to fill until you get to the proper level as indicated on the dip stick.
If you have not made friends with the guy or gal at the Yamaha Parts Department, you should go do that now. They will be a great source of information to you in the future.
Find and use your owners manual.
Thanks for your interest in FixYa.com
Feb 28, 2013 | 1982 Yamaha XZ 550
How do you check the oil level on a 1983 Honda V45
Center stand your motorcycle. If you have an Interceptor have a friend hold the bike upright. Unscrew the dipstick on the back of the right engine cover. Part #4. http://www.bikebandit.com/houseofmotorcycles/1983-honda-vf750c-magna/o/m11968#sch558483 Wipe off the dip stick and place it back into the opening but do not screw it in. Pull the dip stick out and make sure the oil level is between the high and low mark. If the level is low add only JASO MA certified motorcycle oil designed to work in engines with transmission gears and wet clutches.
Jun 30, 2011 | Honda VT750C2B Motorcycles
How much oil what wt.
Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
Feb 03, 2011 | Porter Cable PorterCable DBSI325 3250 Watt...
Transmission dipstick location
the dip stick is located in engine compartment if you stand in front of car with hood open the dip stick is to your left on side of trany, if this car is stick shift and not automatic then theres no dip stick its checked from side of trany by removing a plug and fill until oil runs out a little a lift would be the way to check it, the car must be level
NOTE; some models have a tube with dip stick and some a cap that unscrews on top of trany and when checking fluid you dont screw in just stick in hole to check level when done then screw back in and tighten,heres a diagram to help you find it.c083006.gif
Aug 25, 2010 | 1991 Honda Civic
Can't find oil level stick in engine compartment 2006 bmw 525i Whould you tell me where is it?
The BMW 525I doesn't have a dip stick. The oil level is checked using the "i" menu. Select service status and from there you should choose "check engine oil level".
Jun 27, 2009 | 2007 BMW 525xi Sedan
Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049 Logo
243 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
