Question about Soltek SL-65KV2-T Motherboard
Boot beeps When pc is turned on, I get one long beep repeatedly. Have tried various known good RAM and another good video card with no change. P3 886 MHz 128Mb Ram 4.3 Gb HDD Win 98SE. Have checked all connections and cables and everything seems ok. How can I get it to boot?
  • Ron Janson Mar 19, 2007
    Thanks sandrew. Have reseated everything and not upgraded anything. How can I check the power for the processor? The pc worked ok one day and next day just beeped at me!
    President:
  • 2,961 Answers
Re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Posted on Mar 19, 2007
  • andrew pester
    andrew pester Mar 20, 2007
    Check the power connector to the motherboard, remove and check for shorting, melted pins.
    Only way to check the processor is by using a new one unfortunately, but firstly check your ram, it may be faulty.
Mercury PI865D7 Motherboard system is won't turn on. I Checked SMPS and RAM. it's also a good then what's the problem for this....And Coming high pitched Bee Sound Repeatedly.....
Hello the manual can be downloaded here:
http://www.mercury-pc.com/downloads_list.php?productid=684
Check the ram modules, and the graphic card.
How many beeps comes, when you start the pc ??
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One long beep is a ram module failing.
Try insert one module, and reboot.
The problem could also be, the power supply.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Best of luck
Jan 23, 2013 | Computers & Internet
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
May 25, 2010 | Dell Dimension 3100 PC Desktop
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Computer starts but does not post Athlon XP KM4M DDR
if the system made no beeps after the machine was booted with no ram its a bad board...sorry
Aug 10, 2009 | Computers & Internet
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
Soltek SL-65KV2-T Motherboard Logo
106 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
David
David
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
