Question about Sanyo Refrigerators
Replace light bulb in sanyo refrigerrator
The bulb needs to be replaced, but I cannot get it out. It does not seem to either screw out or pull out. It is in a small compartment on the upper right side of the refrigerator just below the freezer compartment and behind the temperature control dial.
Have someone with smaller hands get it out. Husband had the same problem and had our daughter try and since her hands were smaller, she had no problem. Now the BIG problem we are having is finding a replacement bulb!
Posted on Aug 22, 2009
I have a Sanyo microwave oven EM-S8586W/V and I need to replace the light bulb. Where is the bulb located please?
small screw bulb e14 type for fridges. its behind the screw plate next to were the holes are on the side of the microwave right side. usually 3 wat
May 18, 2018 | Sanyo Microwave Ovens
I need to replace a bulb in the rear lights.
There's a couple pins that are stuck into rubber or plastic grommets.
You really do need to pull it staight back.... maybe a little more from the bottom for that first pin.
Here's a picture that shows the pins:
Jul 26, 2010 | 2004 Ford Expedition
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
Sidelight bulb replacement on 1997 toyota corolla
Remove the screw above the headlamp. Pull the entire side light straight out towards you.
Feb 20, 2009 | 1996 Toyota Corolla
Replace brake light on my 2002 Honda Oddesey passenger side
Open the rear hatch and remove the two taillight mounting screws. These screws are located behind two plastic flaps that are flush fitting and part of the tail light housing. You will need a small flat blade screwdriver to put under the edge of the flap nearest the light. Pry gently (but persistently) and the flap will open to reveal the screw head underneath. (The hinge of the flap is on the side nearest the hatch opening.) Remove the screws with a phillips head screwdriver or an 8mm socket. Now comes the tricky part. Wiggle/pry the taillight housing as straight back as you can. Keep pulling/wiggling until the forward clip releases. Once it does you will be able to access the bulbs by rotating the bulb holders counterclockwise. Pull the bulb straight up out of its socket. Replace with the new bulb. Note how the forward spear point clip fits into its socket at the forward outboard edge of the housing. Fit the clip and push forward on the housing until you can hear the clip snap into place. Replace the screws and fold back the flaps. You're done.
-T
Jan 15, 2009 | 2002 Honda Odyssey
Head and Tail Light Replacement
I have a 1999 GMC Sonoma and have had to replace the lights a few times.
- For the front lights, pop the hood and look to the front.
- Behind each light there are 2 black tabs.
- Pull these up to release the head lights. Be careful. they may fall right off!
- Pull the headlamp assembly out and take note of how the two tabs at the bottom fit into the frame.
- Undo all the bulbs (Some twist while others require you to hold a piece down while you twist to release the bulb) Keep track of which bulbs came out from where
- Once all bulbs are free, replace as needed.
- To reinstall, put the bulbs in the same holes they came out of
- Remember those black tabs you took note of earlier when the assembly came off? It's time to put those tabs back in the slots they came out of.
- Align the black rubber bumpers on the back with their sqaure holes
- Push the Assembly into the frame and have those black tabs ready.
- Once you see the square bumpers on the other side of the frame, slide the black bumpers back on
- Repeat for the other side
- For the tailights, Open your tailgate
- Locate the screws on the sides holding your tail light on (usually one or two screws)
- Undo the screws and take the taillight out
- Undo the bulbs like you did with the headlamps
- replace bulbs as nessecary
- Put bulbs back in
- Reattach tail light (With screws)
A Hayes Service manual also covers these pocedures.
Good Luck!
Jul 24, 2008 | 1998 GMC Jimmy
Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Jul 01, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Loose Light?
MOST MICROWAVE OVENS TODAY HAVE TO HAVE THE OUTER SLEEVE REMOVED TO ACCESS THE SIGHT BULB.
THIS IS DONE BY REMOVING ALL THE SCREWS ALONG THE BACK EDGE OF THE SLEEVE AND PULLING UP AND
BACKWARDS ON THE SLEEVE. SOMETIMES THE BULB ISN'T LOOSE BUT THE FILAMENT IS DANGLING IN THE LIGHT BULB AND OCCASIONALLY MAKES CONTACT WHEN IT IS BUMPED. THE BULB WOULD NEED REPLACED.
Mar 28, 2008 | Sanyo EM-Z2000S Microwave Oven
Refrigerators Logo
312 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Bailey's...
Bailey's...
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
