If you are referring to a password locked on your computer ????? Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator it will prompt you to enter the new password enter the new password and the password is changed
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
hope this helps
