Question about Canon ZR80 Mini DV Digital Camcorder
No picture after not using my ZR80 for over a year now, I can not see anything through the lens. Everything is clean and seems to be working fine except it doesn't show me what i'm looking at or display anything on the screen. If i hit record it records sound and black as the video. What could be causing this?
  • 30 more comments
  • Ransley Nov 02, 2007
    Same thing with my canon zr80. I haven't used it in like a year and when I tried to use it recently I get a black screen. everything seems functional except for the black screen.wtf
  • tnutz004 Nov 06, 2007
    I have the same problem. I have had this camera for about two years and it was working fine at the beginning of the year. Now I can only get audio when I record. Have you found the problem?
  • Anonymous Nov 11, 2007
    my zr80 will only record audio. it will not record video
  • lummidee2002 Dec 13, 2007
    Hi! I have the same problem. I have had this camera
    year. Now I can only get audio when I record. Didnt use camera too much.Have you found the
    problem?
  • fontesrj Dec 14, 2007
    Black screen with sound. can playback already filmed tape in vcr mode.
  • Anonymous Dec 20, 2007
    I am having the same problem with my ZR80. When I record I don't see a picture in the screen and it records black. please help me fix this problem. I've tried playing with the menu buttons, but I haven't gotten any results.
  • rjberkey Dec 20, 2007
    Same problem...audio only, no video. Worked fine earlier in the summer and then the black screen and nothing in the viewfinder this Fall.
    Previously recorded video plays back just fine - both on the camera as well as when connected to the tv.
    Canon is taking a look at ours free of charge but told my wife over the phone that it did not sound like this was the CCD sensor (because we could play back older video ok?)...I am not convinced and this forum tells me this is a common defect that Canon hopefully will accept responsibility for.
  • jaymulford Dec 26, 2007
    Great little camcorder and I love Canon products, but disappointed... The unit seems to function properly. In playback mode, video and audio playback works just fine. In camera mode, image finder and LCD display both operate and show status messages (e.g., battery, mode, date, etc.), but, no image is displayed. Record seems to work, but only records audio, no video.
  • avensislive Jan 06, 2008
    Hi, i am having the same problem as mentioned above except mine is a canon mv700i, although this may be the same model but just a different name. My problem is everything works except i have no picture when in camera mode. In play mode everything is fine i can watch previous recordings...
  • Anonymous Feb 14, 2008
    This is a manufacturing problem & if you call Canon, they will repair it for you.
  • kuangrocky Feb 18, 2008
    same
  • sheree5611 Mar 03, 2008
    I have a Sony handycam, professional model - turn it on and instead of landscape, all you see is lime green.
  • Anonymous Mar 08, 2008
    Same issue, everything works great and when recording I get sound and displays but no picture.
  • Anonymous Mar 11, 2008
    I'm having the exact same issue! Frustrating!
    Call 1-800-828-4040.....there is a defective chip that needs to be replaced and Canon will fix it for free. They even sent me free shipping lables as well....
  • kuiporng Mar 14, 2008
    I got the same problem when using it as camera, but when using it as video to play it is working
  • Anonymous Mar 17, 2008
    Mine was working fine then it sat for a couple of month. Then went to use it again. and the the little LED was blank and when I looked throught the viewfinder it was all black with streaks of white coming in from the left side. When I changed tape it worked for a minute then went back to the blackness. Will give Canon a call
  • Tita86 Mar 17, 2008
    I am having the same problem with my Canon ZR80, i called the 800-828-4040 number and, a representative explained to me that this is happening to all the Canon ZR80 it is a defective chip. They have all gone down. They told me to send it in and they will be taking care of the problem at no cost, as long as the camera has not been damaged or dropped. Make sure to remove your Batt, and and tape in the camera before you send it back.
  • David Hopkins
    David Hopkins May 15, 2008
    Same exact thing, just adding a "Me Too" so that the count will go up.. I just called Canon support and they are sending (email) me all of the information on getting it fixed. Also said that we should have it back in 7 to 10 days. Sweet. Dave
  • Anonymous May 16, 2008
    me too
  • Anonymous May 21, 2008
    Got the same exact problem. Calling Canon now.
  • thewatcher May 21, 2008
    I''d spend the entire morning looking for a camcorder repair place near me, until I stumbled upon this post. My fault for not searching for my model first. I have the EXACT same problem, and thought I somehow damaged on a plane ride. Obviously that's not the case. I'll be shipping mine back tout suite. Thanks!
  • DanimalMN Jun 17, 2008
    Wholly **** thanks for all of these good posts! I was having this same problem after not using it for 6 months. Standard repair was $150.00 and I was thinking of just getting a new camcorder instead of repairing it.
    I then did a little research and found this awesome site. Called the 800 # suggested below and they are going to fix it for free!
    Thanks for posting the 800# and having the tech number available for us searchers.
  • Anonymous Jul 07, 2008
    i have the same problem. everything appears to work fine including playback of already recorded material. but the video camera shows a black screen when recording new material. sound is okay but black screen.
  • Anonymous Sep 19, 2008
    I have the same problem.. no pictures during recording. wen warms up som times its work.
  • jgunice Sep 22, 2008
    I get no picture when filming video. The screen goes black.
  • Anonymous Nov 12, 2008
    About a month ago, my ZR80 suddenly went blank. Just like the other posts. I've now contacted Canon through this website's number and hopefully will get it fixed for free! Thanks!
  • trivia58 Nov 16, 2008
    Same problem. It records, but no picture, just blackness.
  • Anonymous Nov 26, 2008
    same same
  • Anonymous Jan 10, 2009
    no display on lense
  • Anonymous Feb 13, 2009
    Thank you for posting the info! I have the same problem and contacted Canon.
    I called the number, they walked me through a few steps to see if it was another problem, it was not, and so they sent me a form and the UPS shipping label to send in my camcorder, they are fixing it for free!!!
  • dondsne Feb 20, 2009
    same problem with my mv5i, blank screen (stripes across screen when problem first occured) when recording but playback works fine. so glad i found this site!!!! cheers
    President:
  • 3,130 Answers
In the first half of October, 2005, a number of digital camera and camcorder manufacturers issued service advisories involving a range of digital camera models (as well as some digital camcorders and PDAs that incorporate image sensors). In each case, the story was similar - CCD (image sensor) failures, particularly in conditions of high heat and humidity, led to cameras capturing images with either no picture at all, or with extreme distortion and severe purple or green color casts. An example of the latter symptom, courtesy of the Konica Minolta Europe website, can be seen further down this page. We first started hearing about this problem in late September and early October, 2005, with a significant increase in reader emails about it in the first week of October. The problem understandably caused considerable concern among our readers, with many wondering whether this was an ongoing problem that could affect current cameras. Initial service advisories by Sony, Canon, Fujifilm and Konica Minolta were soon followed by announcements by Nikon, Ricoh, and Olympus. Affected cameras were all manufactured between 2002 and 2004, the underlying problems have apparently been found and corrected, so no cameras currently on the market are affected. (We are assured by sources that new cameras purchased today will not be affected by this problem. See the "What caused this problem" section at the bottom of this document, for a more detailed discussion of possible causes.) We here at Imaging Resource did a little digging into the problem, and it appears that the problems trace to certain models of image sensor chips manufactured by Sony between 2002 and 2004. (Fujifilm has stated that they manufacture their own CCD chips, so it's not clear whether or not the problems with their cameras are in fact related to those of the other makers.) The problem can take any of several forms, but all involve severe color shifts and/or severe distortions of the image. The images below show two examples (courtesy of Konica Minolta) of what the problem might look like, if your camera falls prey to it. In the early stages of the problem, the camera may still capture recognizable images, but with a washed-out appearance and a strong magenta or green tint What products may be affected? Quite a number of products may develop this problem, including digital cameras, camcorders, and even PDAs (Personal Digital Assistants) that incorporate an image sensor. The following is a list of affected models by various manufacturers that we are presently aware of. We will update this list as new information becomes available. We recommend that you check the site regularly for this and other breaking news. Here are lists of the affected products, grouped by manufacturer: Canon Digital Cameras Camcorders PowerShot A60 PowerShot A70 PowerShot A75 PowerShot A300 PowerShot A310 PowerShot S230 Digital ELPH / Digital IXUS V3 / IXY D320 PowerShot SD100 Digital ELPH / Digital IXUS II / IXY Digital 30 PowerShot SD110 Digital ELPH / Digital IXUS IIs / IXY Digital 30a Additional digital cameras added in the fall of 2006 to the original service advisory by Canon include the following, all of which went on sale starting from 2002 to 2004, depending on the specific model: PowerShot A40 PowerShot A80 PowerShot A85 PowerShot A95 PowerShot S1 IS PowerShot S60 PowerShot S200 DIGITAL ELPH / DIGITAL IXUS V2 / IXY DIGITAL 200a PowerShot S330 DIGITAL ELPH / DIGITAL IXUS 330 / IXY DIGITAL 300a PowerShot S400 DIGITAL ELPH / DIGITAL IXUS 400 / IXY DIGITAL 400 PowerShot S410 DIGITAL ELPH / DIGITAL IXUS 430 / IXY DIGITAL 450 PowerShot S500 DIGITAL ELPH / DIGITAL IXUS 500 / IXY DIGITAL 500 (including White Limited version) MV600i MV630i MV650i MV700i MV730i MV750i MV5i MV5i MC MV6i MC ZR60 ZR65 MC ZR70 MC ZR80 ZR85 ZR90 Elura 40 MC Elura 50 According to the updated advisory, available on the company's US website (as well as other regional Canon websites), the additional eleven digital camera models shown above in red may now be eligible for free service regardless of warranty status, should any malfunction be caused by the CCD sensor. For repair instructions, visit the Canon USA support website. To read the specific service advisory for your model, use the pulldown menus to browse for your specific model, or simply type the model number into the box provided at the bottom of the page and click the "Search" button. The Canon support website holds no forms or other needed documents, so you can save yourself some time (if you live in the US or Puerto Rico) by just calling the Canon Customer Support line at 1-800-828-4040. Support hours are Monday-Friday 8am to 12 midnight, and Saturday from 10am-8pm. (All times EST.) Alternately, you can send email to: carecenter@cits.canon.com.
Posted on Mar 21, 2007
Fantastic solution...free service including shipping Call 1-800-828-4040. Glad I found this site.
Posted on Jul 15, 2008
I called Canon Support on 11-02-12 about the black screen chip failure and spoke to one of their Support Reps. His reply was simply Canon no longer supports this model ZR80 and he turned me over to a Canon Loyalty Representative. Only option now available is to select another camera and the would provide a discount and free shipping to return the problem ZR80. to their Recycle Program
Posted on Nov 02, 2012
Posted on Mar 11, 2008
Yes, this was exactly the problem. Thanks for posting this information. Canon repaired my ZR80 camcorder at no charge.
Posted on Oct 21, 2007
Ccd imager is bad contact canon
Posted on Mar 20, 2007
2 Suggested Answers
SOURCE: no picture
If you want to have it done for free check the canon service note - it may help and will not cost you a broken penny. http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9740&keycode=2112&id=48266
Posted on May 07, 2009
My Canon Rebel will not autofocus. It takes pictures just fine with manual focus. I see several posts about this and no solutions other than the user doesn't know how to take a picture. We've had the...
A few suggest about this problem. First in manual or auto focus mode does the green in focus confirmation light come on in the lower right corner of the viewfinder? Are you shooting in One Shot-AF, have you selected an Auto Focus Point are your pictures in focus? I know you've been using this camera for 2 years and these questions you need to ask yourself. If that green confirmation light comes on then the picture will be in focus. a few things that will mess up focus are little or no contrast. No contrast like huge expanses of water, sky, glass or infinity will render a auto focus system near useless. Something that is good is that you haven't said anything about error codes which is good. These questions my sound lame but ask yourself this when was the last time I cleaned the lens (Front Element) use a lens cloth for this and huff on it if a little moisture is needed. Do you change lenses often and when was the last time you checked your sensor for dirt? If you have had the lens off you should check the rear lens element for finger prints or oil. A dirty rear lens element will cause everything to look as if it's shot in a dream world. Check your camera sensor buy taking a (manual) focus shot of a piece of clear blue sky download it to the computer increase the size to 100% and check out the blue for dirt. A camera that's two years old and used "normally" may need the sensor cleaned. But go back to this infocus light if it's coming on and the pictures are out of focus then you have another problem as in dirt.
Hope this was a little insight into your problem
Jan 11, 2011 | Canon EOS Rebel XSi Digital Camera
Lens issues with Nikon D40 camera
Have you ever cleaned the contacts on the lens and the camera body where they meet? If not, do so now with a cotton swab lightly dampened with rubbing alcohol.
May 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
Camera won't take a picture when autofocus is on
It sounds like you have a problem with the auto focus on the lens. The 18-135 has a focusing motor inside the lens itself. If this motor is not working, then it won't focus. It could also be the contacts (small and silver on the lens look like ball bearings buried halfway into the top part of the lens where it connects inside the camera body) or the contacts inside the camera body. These can be CAREFULLY cleaned with alcohol and a QTip or a clean pencil eraser. Just make sure you don't get anything into the lens or camera.
If the camera is over a year old, it may just be time to take it to the camera shop for a cleaning.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
My screen is showing like multicolors & it still takes pics
Hi There, If your screen still lights up, sounds like the LCD Panel is cracked.
Dec 11, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
No picture
Dec 23, 2007 | Canon ZR80 Mini DV Digital Camcorder
Everything seems fine but won't take a picture, no error message
First of all, you should know that when someone advises you to buy more stuff because of a problem you have, it's very possible they're ripping you off! It's a disgrace that they took advantage of you and sold you all that stuff..
Now, to your problem..
First of all, are you absolutely sure that the camera autofocuses properly? That would be the first thing to check. To make sure, turn the focus selector (on the lens) from auto to manual, try to focus manually (it doesn't matter if it's not 100% accurate) and press the button.
If that's not the case, try other modes. Try the camera in (M)anual mode, for instance. Also, just in case, try to clean (with a dry fabric) the battery contacts and also the battery contacts of the camera.
Dec 16, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Darkened Images
Sounds as if your diaphragm may be sticking due to either the camera or the lens. Look at the back of the lens and work the small tab with the aperture ring set to f32 (or 22). See if the tab moves smoothly but with resistance from a spring, or if it sticks or moves roughly. If it does this with other lenses too, another possibility is the aperture lever on the camera. Mount the lens and set it for f22 or so and use your depth of field preview to see if the lens is stopping down smoothly. In either case it may need professional repair.
Nov 02, 2007 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Cannon Digital Rebel XT
"it no longer takes pictures" i'll need a bit more information from you but for now my first suggestion would be to (if the camera still powers up) try testing the shutter by finding the "sensor clean" option in your menu. (i don't have mine in front of me at the moment, but it's usually one of the last options) first remove the lens and select the sensor clean option. if the shutter opens, then the camera body itslef should be fine. the camera will instruct you how to close the shutter after. be extremely careful when the image sensor is exposed like this, make sure not to touch it and be sure to be in a clean area (dust on your sensor will frustrate you beyond belief) now i've had problem after problem with this standard 18-55mm lens. if the lens can't find a focal point, it won't fire. try switching to manual focus and see if it fires. if while focusing manually there is any resistence or grinding, chances are your lens is shot perhaps from being dropped or there is debris preventing auto focus mode to find a focal point. "i've had my camera for about a year" if you bought it new and have had it under a year, it should still be covered by warrenty and canon will take it back and make repairs (they gave me a new lens when this happened to me)
Apr 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon ZR80 Mini DV Digital Camcorder Logo
1,552 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
