My Panasonic Workio 3010's alarm is blinking, it still makes copies, but it says Call for P/M Fuser Web with a tool symbol next to it, any help would be GREATLY appreciated.
Thanks
Danielle
That means that the fuser web. a cloth like material is almost finish. and needs to be replaced.so you need to call a technician to replace that part. p/m means preventative maintenance = fix it before it breaks.
Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
To turn this feature off. These 3 buttons need to be pressed and held down in this order. Press and hold the Function button then Press and hold Original Size (Ledger) then Press the 3 You ar now in the service mode. Press the #5 then start Scroll to #88 and select Turn off then press close Press and hold Funtion and Clear to exit service mode
Hard to say without knowing how many copies it has done.
Suggest that it may need the mirrors/optics cleaned,may require a new drum,drum blade,fuser web,fuser roller ,developer or may even be non genuine toner.Suggest that a technician has a look at your copier..
PM is preventive Maintenance - It's kind of like changing your oil! you need to have certain expendables replaced such as Fuser. There should be a P/M kit you can order for this that will include everything.
error code E4-01 means you have a fuser warm-up temperature problem. try a lbp fuser reset in service mode. i dont know what you password is so i cant tell you how to get there but good luck
In the service mode there might be an automatic fuser and drum cleaning mechanism that could be activated. The fuser web is in the drum section of the unit and when this is coated with toner and the cleaning mechanism is inactive, you could get this problem.
Let me know if you do not know how to get into the service mode of the copier. It normally is pressing the following three buttons simultaneously - Original, Function and the number 3. It may take a few tries before you get the sequence properly. Also, if it requests a password, try 0000 or 00000000 (8 zeros or 4 zeros)
