Question about Brother MFC-8840D All-In-One Laser Printer
Doc. Cover Open displayed...remove original and then close cover.
Unable to delete this message from the display panel...the machine will not allow me to perform any functions. Any suggestions?
  • Brother Master
  • 1,113 Answers
Left rear hinge is cracked stopping lid from closing fully. Tape down black switch left corner near glass rear. Or replace hinge
Posted on Dec 15, 2008
Get an 'unable to print 6f' error for my MFC-8370 machine.
https://help.brother-usa.com/app/answers/detail/a_id/145079/~/unable-to-print-6f
"Unable to Print 6F"
The message "Unable to Print 6F" will appear on the display for one of the following reasons:
i. A foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine;
ii. Mechanical malfunction.
To attempt to clear the error, continue to step 1.
1. Using both hands, use the finger holds on each side of the machine to life the scanner cover into the open position.
- Do you see the scanner cover support arm located on the left side of the machine?
- If yes, go to step 2.
- If no, verify you have opened the scanner cover (as in the image above). If the document cover was opened, you won't see the scanner cover support arm. Close the document cover and go back to step 1 to open the scanner cover.
2. Carefully check the left (2) and right (3) hand corners and the center inside the machine and remove any paper scraps that may be jammed.
3. Using your hand, move the print head from left to right, checking carefully for any paper scraps stuck under the print head. Remove any if found.
If the print head is in the right-hand corner, press and hold down the for at least 5 seconds until the print head moves to the middle. This will allow you to check the right corner inside the machine for any paper scraps.
4. Leave the scanner cover open and turn the machine around so you are looking at the back of the machine.
5. Open the Jam Clear Cover (1) on the back of the machine.
6. Check inside for any foreign objects or jammed paper. Remove it found.
7. Close the Jam Clear Cover, then turn the machine back around to the front.
8. Lift the flat-bed scanner cover to release the lock (1), then gently push the scanner cover support down (2) and close the scanner cover (3) using both hands.
- If "Unable to Print 6F" still on the display, go to step 10.
- If "Unable to Print 6F" has cleared, go to step 11.
10. Unplug the machine from the power outlet for approximately one-minute, then plug it back in.
- If "Unable to Print 6F" still on the display, go to step 12.
11. Print a Print Quality Check Sheet (PQCS).
a. Press on the Touchscreen.
b. Press Test Print.
c. Press Print Quality.
d. Press OK. A PQCS will print.
- If the PQCS print successfully, your machine is working properly. The issue has been resolved.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have not cycled the power, go back to step 10.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have cycled the power, continue to step 12.
12. Your machine will require service. Any faxes received while the error message is on the display will automatically go into the machine's memory due to the product's inability to print. If there are faxes in memory, you can transfer them to another fax machine so they are not lost.
- If you don't want to transfer faxes, go to Warranty and Service Options.
- If you want to confirm and transfer received faxes in memory, go to step 13.
13. Transferring stored faxes to another machine.
To transfer data from your fax machine to another fax machine, you must have already programmed the Station ID in your machine prior to getting the "Unable to Print 6F" error message. If you did not already have your Station ID programmed into the machine before getting the error, you will not be able to transfer faxes in memory. Continue to Warranty and Service Options.
a. Press to temporarily interrupt the error message.
b. Press on the Touchscreen.
c. Press All Settings.
d. Press ? or ? to display Service. Press Service.
e. Press Data Transfer.
f. Press Fax Transfer.
- If "No Data" appears there are no faxes in memory to transfer. Press , then continue to Warranty and Service Options.
- If there are faxes in memory, the display will prompt to enter a fax number. Enter the fax number including the 1 plus the area code, then go to step g.
Warranty and Service Options:
Your machine has a two-year limited exchange warranty. You may use the link below to find a Brother-authorized service center in your area. You may also contact Customer Service for additional warranty options.
Locate a Brother Authorized Service Center:
https://www.brother-usa.com/service/
Contact Brother Customer Support:
https://www.brother-usa.com/askus/ Click here to display all models covered by this answer.
Was this answer helpful?
Nov 10, 2012 | Brother MFC-8440 All-In-One Laser Printer
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Unable to clean can you help
The message "Unable to Clean" will appear on the display if there is a mechanical malfunction of the Brother machine OR if a foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine. Check the machine for any foreign objects by following the steps listed below:
1. Open the scanner cover by pulling up on the lower right corner of the cover until it locks into place.
2. Look inside the Brother machine and remove any foreign objects.
3. Close the scanner cover by lifting it slightly to release the lock, gently push the scanner cover support located in the back of the unit and then close the scanner cover.
If the message Please Wait - Unable to Clean continues to appear on the display the machine will need to be reset. To reset the machine, unplug it from the power outlet for several seconds and then plug it back in. If the date and time appear on the LCD, then the problem is resolved.
If the message continues to appear on the display your machine is within warranty, you can locate a Brother Authorized Service Center (ASC) in your area by clicking on the link below:
http://www.brother-usa.com/service/default.aspx or contact Brother Customer Service by calling 1-877-Brother (1-877-276-8437) Monday through Friday, excluding holidays.
If your machine is out of warranty, you can locate a Brother Authorized Service Center using the information listed above.
If you need more help come back.Post /thumbs / testimonial are welcome!
Nov 28, 2010 | Brother DCP 115C All-In-One InkJet Printer
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Clean Unable 46 how pleaes brother dcp130c
    The message "Unable to Clean. " will appear on the display if there is a
    mechanical malfunction of the Brother machine OR a foreign object, such as a paperclip or ripped piece of paper is stuck in the
    machine.
    First, check the machine for any foreign objects:
    cover until it locks into place. Look inside the Brother machine and remove any foreign objects.
    2. Close the scanner cover by lifting it slightly to release the lock,
    3. If the error message continues to appear on the display the machine
    will need to be reset. To reset the unit unplug the Brother machine
    from the power outlet for several minutes and then plug it back in.
    If the message continues to appear on the display and your machine is
    Please Let me know if this works, or if it does not.
    Thanks,
    Ryan Frame
    Creative Energy Associates Technical Center
    Aug 02, 2009 | Brother Office Equipment & Supplies
    That usually means some sensor giving you trouble.
    This is what brother recomends:
    How do I clear the message Cover Open or Please Close Cover from the display?
    The message Cover Open or Pls Close Cover may appear if the front cover
    for the drum was not closed securely. Verify the cover is closed
    securely by pressing the cover release button located in the front of
    the unit below the Output Tray Support Flap and open the front cover.
    Close the cover until it clicks into place.
    If the message continues to appear on the display verify the drum and
    toner assembly is installed correctly by following the steps listed
    below:
    1. Press the cover release button located in the front of the unit and
    2. Remove the drum unit and toner cartridge from the unit by lifting it
    up and out. Place it on a drop cloth or disposable paper to avoid
    scattering toner.
    3. Hold down the blue lock lever located on the right side of the drum
    and lift the toner cartridge out of the drum unit.
    4. Reinstall the toner cartridge into the drum unit by inserting it in
    the drum until it clicks into place
    5. Reinstall the drum unit into the unit. Make sure it is securely in
    place.
    6. Close the cover until it clicks into place
    If that doesn't fix it, I guess you will have to talk to their support people.
    Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
    My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
    Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
    Happy debugging Mukesh
    Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
    Error mesage
    No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
    I open the cover and it says "Please Close Cover".
    I close the cover and it says, "Please Open Cover"
    and this happens forever!
    Does anyone have any ideas? Can anyone help me?
    Stefan
    Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
    Brother MFC-8840D All-In-One Laser Printer Logo
    201 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
