Question about Sony VAIO VGN-S460 Notebook
How To Remove My Hard Drive????????
Can anybody tell me how to remove my hard drive from this laptop??? Mine crashed so i'm trying to replace it. I need to get this fixed A.S.A.P!! Thanks A Million!! Rob
  • 385 Answers
This is a complicated process and I advise you to be very cautious and carefully organize all screws and cables that you unplug in a clean and undisturbed area. Pay keen attention as to where cables are unplugged from so you can plug them in when hard drive is inserted. I must say proceed at your own risk because it might get frustrating if you are not careful and organized. First, turn over the laptop and loose all 7 screws on the perimeter of the laptop. Loose one screw in the middle and 2 on both sides of the battery (total 10 screws). Remove the battery, there are two clips there holding the keyboard. Release those and remove the keyboard and unplug main keyboard data cable from motherboard. Unplug the power switch cable, and the touchpad cable from m/board. Unscrew 3 screws from under the keyboard to remove the top cover of laptop. When that is removed you will see the hard drive in the bottom right. There are 3 screws holding the hdd to the system and 4 holding the enclosure that needs to be removed. Unplug the sata cable and use it for new sata hard drive. I hope you have had the patience to do this as this is a job for a technician. If you have succeeded, congratulations.
Posted on Mar 19, 2007
I have just replaced my old 80 GB hard drive for a new 250 Gb, I followed the instructions by Lolita, so if you are willing to upgrade your laptop this is the right place to look for info. Thanks Lolita, and thanks FixYa.
Posted on Oct 04, 2007
  • 624 Answers
Robqx4, Rather than reinvent the wheel here is a link to instructions someone else posted. They?re fairly easing to follow and well documented with pictures. If you have any other questions let us know otherwise please don?t forget to rate this post.
The led that indicates that the hard drive is been accessed does not go on and the laptop does not go on. so does it mean that the Hard drive has crashed
Possibly. Remove the hard drive and boot the laptop. You should get a screen telling you there is no bootable device found. If you do, the hdd is possibly faulty.
Jan 25, 2014 | Computers & Internet
Tip
How to troubleshoot a system that will not boot to the hard drive.
  1. Ensure that there is no diskette in the A: drive if system is equipped with a 1.44 Floppy Diskette Drive. If a disk in the drive, remove it and reboot.
  2. Boot to the BIOS, reset defaults, reboot
  3. If system still will not boot to the hard drive, power off, disconnect all peripheral items (Printer, scanner, external drives and USB drives) reboot.
  4. At this point, boot to Diagnostics partition, or CD (F12 menu on some systems, Some HP systems have Hard drive diags in BIOS, Fn+Power for Dell Portables, CTRL+ALT+D for some Dell Desktops) If the hard drive fails diagnostics, replace the hard drive. If the drive passes diagnostics, it is not a guarantee the drive is good, just no fault was detected.
  5. If the drive passes diags, then see if you can boot to a Windows CD/DVD. If you can't, either remove, turn off in BIOS or disconnect the hard drive, and see if you can boot to the Windows Media. If you can with the HDD disabled/removed/disconnected, again, replace the HDD.
  6. If you can boot to the Windows Media, then go to Recovery Console in XP and run CHKDSK /R (Vista or Windows 7, run the repair my computer option off the menu, this may take multiple passes to fix) If this fails to resolve, then boot back to recovery console and run BOOTCFG /REBUILD (This is already done in Vista/7 in the repair tool)
  7. If that fails, you will most likely be reinstalling Windows. If the Windows install crashes during a file copy, try RAM modules one at a time (Windows install is still the best RAM test we have) If the Windows install still crashes, replace the Hard Drive.
on Dec 27, 2009 | Computers & Internet
Internal hard drive not found
Possible crash of the hard drive or the partition. Try and see to reboot and get the drive to work before confirming.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron Error Msg 2000-0141 cannot detect Hard Drive
You might have a hard drive crash, Meaning the hard drive needs to be changed out in it.
This happends over time,heat,AGE and all other sorts of occurances. Hard drives to not last! period! The only fix here is to have the hard drive replaced with new. Now in this model the hard drive should be on the bottem of the unit under a cover. you take a screw driver and open that hatch and take the hard drive out. You can bring that to a local best buy or computer shop and have a replacement put in Around $89-150 bucks depending on size you get and brand.
Thanks I hope this helps you out please do be considerate and leave postive feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2010 | Dell Inspiron 1525 Notebook
My hard drive crashed how do i change it properly
there should be a screw or two screws on the bottom of the laptop next to a release. unscrew the screws and try sliding out the hard drive, if there is a black piece of plastic thats on the end carefully remove it, the pop that piece onto the new one. unless your laptop uses sata drives, then just pop a new hard drive in.
Apr 26, 2010 | Toshiba Satellite 5005-S504 Notebook
Smart failure predicted on hard disk/ acer laptop during booting
you'll need to backup your critical info on a storage medium and replace your hard drive. As there is noo telling when the hard drive will crash maybe today maybe next year. If you need help in removing the hard drive please state model and i will help
Feb 21, 2010 | Acer TravelMate 507T Notebook
Hard drive crashed installed new drive but have no drivers to boot the operating system,
plaese check motherboard setting and then boot setting check ....set the booting order is as
1st hard drive
2nd cdrom
3rd other etc.
then save this setting and reboot....
try it i think it is solved.if still unsolved then check the plug hard drive.
Aug 22, 2009 | Acer Aspire 5315 Notebook
Error : 0x400110020000100A
Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
Jul 22, 2009 | HP Pavilion DV6700T Notebook
Trying to find a way to reset or bypass the HDD1 user password on my Toshiba A135-4527 laptop. It was reset somehow to something we do not remember. Hoping I do not have to replace the harddrive. Saw...
The hard drive password is set from the BIOS configuration where the hard drive was installed and you need to know the password to remove the existing password. You can only remove the password from that computer's BIOS and moving the hard drive to another omputer will not allow you to remove the password or access any data on that hard drive because the password is stored in the hard drive's firmware. This password protected hard drives prevents unauthorized access to the data on that hard disk.
Removing the BIOS battery will reset the BIOS but will not remove the password.
Some computers have been setup with Power On Passwords and/or hard drive passords and it is possible to hack/read the Power On Password that is stored on an EEPROM chip on the laptop, but it is not a simple process.
You will need to buy a new hard drive and now you also have a nice paper weight.
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Powermate Eco Hard Drive Crashed
Hello
instructions on how to remove and replace the hard drive are on this PDF document.
http://support.necam.com/mobilesolutions/hardware/Desktops/eco/819-201002-000med.pdf
You will need a pdf reader to open the document, if you are unable to open it download a pdf reader here
http://www.adobe.com/products/reader/
Can you remove the hard drive from the computer, write down the details that read on top of it, and also if you could look at the connectors and tell me the details so I can make sure I direct you at a proper replacement.
Thank you,
Ekse
Feb 03, 2009 | NEC PowerMate eco PC Desktop
Sony VAIO VGN-S460 Notebook Logo
1,335 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
