Question about Coffee Makers & Espresso Machines
Gaggia Baby Classic
Hi there.
I've took the coffee maker apart and located the leak, it's coming from the selonode valve, it's made by CEME , it's leaking at the base of the brass connection.
Can you please tell me how to seperate the two, or does it come as one.?
Also, where could i buy a replacement. ?
Many thanks
Roger
    Top Expert:
  • Coffee Maker... Master
  • 52,690 Answers
Check with the manufacturer,,quite probably it is a non repairable unit
Posted on Nov 02, 2017
  • 2039 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
  • 5 Answers
SOURCE: gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
EsWorld
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
EsWorld
  • 1618 Answers
SOURCE: Baby Gaggia making a bitter brew, help!
Have you tried backwashing, then removing the shower and screen from the grouphead to make sure that there is no coffee buildup on the screen.
As for the leak around the portafilter, the group gasket needs to be replaced,
Posted on Jul 03, 2009
EsWorld
  • 1618 Answers
SOURCE: The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Posted on Jul 15, 2009
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Leaking water
It sounds like the main valve is faulty. Replacements are available or you may be able to dissasemble it and replace the seal.
Hope this helps.
Sep 04, 2008 | Gaggia Baby Espresso Machine
Gaggia syncrony compact coffee machine
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Jul 22, 2008 | Gaggia Baby Espresso Machine
Feb 03, 2008 | Gaggia Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
75 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
