Question about Brother MFC-8840D All-In-One Laser Printer
Doc. Cover Open displayed
Whatever I try I can't get this message off the display panel and am unable to fax, copy or scan. Any suggestions?
  • 81 Answers
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Posted on Dec 15, 2008
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Unable to scan, copy or fax message on HP C6180
    Please follow the steps and then let me know the results:Click Here
    May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
    To reset the sensor after installing a new toner cartridge follow these steps.
    1. With unit powered On, open the front cover.
    2. Press the "Options" key. Display will show "Replace Drum?"
    3. Press "Start" key.
    4. Press 1,0 .
    5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
    6. Close cover and see if Toner Life End error message has gone.
    Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
    Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
    Printer won't print
    Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
    Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Brother 8840D ADF not working. The flat bed scanner runs instead for fax or copy. Displays Doc Cover Open message
    Open ADF and close again. There must be tab in the ADF which is not pressing a microswitch located in the lower part of the ADF. IF you can locate it, try pressing it manually.
    Jun 06, 2009 | Brother MFC-8840D All-In-One Laser Printer
    I have a Ink System Failure.
    IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
    Press the On button to turn the printer off.
    Unplug the power cord from the back of the printer.
    Remove all the ink cartridges.
    Wait two minutes.
    Plug the power cord into the back of the printer.
    Press the On button to turn the printer on.
    Install the ink cartridges when prompted.
    If the error code does not display, the issue is resolved.
    If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
    Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Doc. Cover Open displayed...remove original and then close cover.
    Left rear hinge is cracked stopping lid from closing fully. Tape down black switch left corner near glass rear. Or replace hinge
    Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
    "Unable To Change" message. Tried all suggested fixes none work. Can you provide any additional help beyond the standard fixes. Nothing is jammed, turning it off for even days doesn't remove the error...
    press menu then start bk copy then fourtimes arrow up. what error code does the machine display?
    In case you have an error 50 you have to open the printer cover and to reinsert the encoder strip which is out of position into the ph. This occurs sometimes after a serious paper jam.
    search error 50 for dcp 110, 115 or mfc 210 here. its the same procedure.
    Dec 17, 2007 | Brother MFC-5840CN All-In-One InkJet...
    Brother MFC-8840D All-In-One Laser Printer Logo
    319 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
