Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Nothing wierd...just no rinse/no spin/no drain with the whirlpool
My Whirlpool Ultimate Care II washing machine starts off perfectly! It will fill with water on any size load. It will agitate the clothes. When it's time for the rinse cycle, it just stops. No rinsing, no spining, no draining! I can still turn the knob but there are no strange sounds, no wierd smells, no leaking! Any suggestions?
  • Anonymous Mar 17, 2014
    stops mid cycle error message was dl or ld cannot recall now, but will not work. had to turn breaker off to turn machine off, turn breaker back on, machine has powere but only makes odd sound does nothing - cloths still had suds so didn't rinse.
  • 85 Answers
Sounds like you have a bad lis switch asm.
Posted on Dec 16, 2008
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not run or drain
My wash machine doesn't open from the front but I am having problems with it not draining
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
517 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
