Question about Mitsubishi WS-55859 55" Rear Projection Television
Power surge Mitsi WS55859
Many power surges in my area this morning. My TV is on a surge protector but it's older and I don't know how effective it is. I got the set unplugged after the 2nd round of surge. You mentioned you had a solution? I love this TV, but can't spend a lot of money on repairs right now. Any help would be appreciated Mr. Techman. You can reach me at schroederstn@bellsouth.net. My name is Christine.
Need new capacitor for the dm modul
Posted on Dec 30, 2008
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
Their was a blackout in my neighborhood. The next day in the morning i tried to turn on my 50inch HP Plasma and it made a loud popping sound. The volume on the tv still works.
Hello.
You probably did not have that tv plugged into a surge protector. When the power was restored, a surge came through the line. A power surge is a spike in voltage above the maximum a tv, appliance etc. can handle of 169 volts. They are very brief, usually lasting millinths of a second. Power surges can vary in duration and magnitude, varying from a few hundred volts to several thousand volts.
That said, now what do you do. If the tv is under 3 years old I recommend that you take it into a local TV repair shop for a free estimate of repair. If it is older than that, I would not repair, just replace. J.
Sep 12, 2010 | HP Televison & Video
Power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Mitsubishi WS-55859 55" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
