Question about Samsung SCX-5530FN All-In-One Laser Printer
I need to know how to send a Broadcast fax to multiple numbers
I have the same reminder to send to approximately 75 local clients/business associates. Most other faxes will allow you to chain a series of fax numbers to send the same info.
What is the sequence?
  • stephanie_ne Dec 18, 2008
    Perfect, thanks!
    I don't have a manual; otherwise I wouldn't have asked.
    Sergeant:
  • 236 Answers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Posted on Dec 15, 2008
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 18, 2010 | Brother IntelliFax-4100e Fax
Looking for a definition for "Sequential Broadcast"
Sequential broadcasting is sending the same fax document to multiple recipients, using either multiple coded-dial numbers, and/or a group dial setting.
Dec 28, 2009 | Canon imageRUNNER 1023iF Black and White...
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxing to multiple numbers
In faxing, it is called a broadcast.If you have the manual you can look in the index and locate it easily.Goof Luck
Mar 27, 2009 | Sharp FO-4400 Fax
Problems sending to a particular number
Try sending your fax to a lower baude rate to 14,000 bps, I had this problem before and I solved it by sending to a lower sending speed bacause the line was very noisey.
Mar 16, 2009 | Canon LaserCLASS Fax 710 Printer
Settingup a group fax number
you will need to go to the broadcast mode for multiple numbers
Jan 19, 2009 | Brother IntelliFax-2820 Laser Fax
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Multiple faxes
you can send it seperat only
Sep 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
Samsung SCX-5530FN All-In-One Laser Printer Logo
248 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
