Question about Lexmark F4270 Plain Paper Inkjet Fax
Won't send faxes
I have just got my new Comcast Phone lines and every time I try and send a fax now i get a busy signal ??
won't transmit
  • ceechel Dec 16, 2008
    Got Ya,,,thank you...:O) but is there any hope of being able to which it over ,,,symular to the new Digital TV switch over?
  • ceechel Dec 17, 2008
    Thank you ...yes I allready have an efax account..but my husband has yet to crossover, along with the rest of the office.
    "but what i did find out"....
    ( that if you use those old DSL Filters that we all first got for our phone lines at home)
    Suppose to will help with the Digital transmission...
    Have yet to try it but I'll keep you posted
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices. Comcast phone lines are DIGITAL.
Posted on Dec 15, 2008
  • Leroy Elliott
    Leroy Elliott Dec 16, 2008
    No, fax is dead. Now it's scan to email.
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Would like to connect a fax but only port 1 or (tel 1) port 2 does not work, should i send back to comcast or reset modem
There is nothing wrong with your modem. Comcast charges extra for a second line. Depending on your model of fax machine, there should be both an input ond an output on the back of the fax machine. Plug the fax machine into line 1 on the modem. Then, plug your phone into the input on the back of the fax machine. If you fax does not have both in and out, then you can purchase a "Y" phone line adapter from your local electronics store.
ps. VoIP is a digital line... Facsimiles are analog signals... Sending analog signals over digital lines is not recomended. If you are wondering "why?" (and understand tech jargon) VoIP is sent via UDP, which is a connectionless protocol (does not retransmit dropped packets) Fax machines use TCP, which does resend dropped packets. This variance in Qualiy of Service sometimes cases strange activity such as both lines (sending and receiving) dropping connections, faxes taking a long time to transmit (due to constant resending loops), etc. It does work... kind of. I would just not assume that faxes made it to their destination until it gets confirmed.
Dec 31, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Oct 04, 2009 | Canon MX310 Office All-In-One Printer
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP J6480 Fax Problems both Sending and Receiving...
Comcast is lying to you. Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Feb 04, 2009 | Digital Products Hewlett Packard OfficeJet...
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
I get calls all the time about fax issues. I work for Comcast and have guided people to the right answers about third party devices. We use a digital connection. Analog is a dying medium. Most calls are concerning HP and Brother but I know others fax machines have had problems too. The new HP machines have a digital setting. HP is aware of digital issues and can help you. It is unfortunate that old fax machines are not digital but a new fax is inexpensive if you wish to buy one. Analog takes up too much space. An example: Six digital television channels can fit in the same space (bandwidth) as one analog. That is why the FCC mandated the change. The same goes for phone lines. I Google almost every problem concerning fax machines and if you go past all the upset comments you will get to the comments that offer remedy. I also wanted everyone to know that a second, no frills fax line from Comcast is very inexpensive and our way of offering a dedicated fax line intead of a distinctive ring fax option.
Mar 21, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Sending faxes
I believe if you have comcast it is a different signal coming in, you probably bought the package for VOIP capability when Comcast was having that promotion. The phone has to be a regular analog phone line not digital, that is probably your problem. Try changing the settings or line it should solve your problem, or call Comcast to guide you along. Cheers!!
Mar 02, 2007 | Lexmark OfficeCenter X3350 All-in-One...
Lexmark F4270 Plain Paper Inkjet Fax Logo
227 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
