Question about Sony Playstation 3 (PS3) Console
I have an sdtv and ps3 dosen't show picture or sound
I have an sdtv by ilo and the ps3 does not show picture or sound i've tried using component and av cables
I had the same problem and was told to turn off the console and hold the start button down for 5 seconds. Have not tried it yet since I am at work.
Posted on Dec 16, 2008
2006 ilo sdtv code
ILO universal remote code - Fixya
www.fixya.com/support/t149216-ilo_universal_remote_code
ILO universal remote code There is no code for ILO TV in my universal remote codelist. ... I have a 27" ilo sdtv. Bought the ..... Sep 09, 2006 ' iLO 2600 Television ...
i have a ilo sdtv and the remote codes direct tv gives wont ...
https://answers.yahoo.com/question/index?qid...
Dec 18, 2008 - does anyone know what to do i can't even find the manufacture for this brand.
RCA 4 digit codes (3) - eliztech.com
www.eliztech.com/remotes/rca-codes-4digit-v3.php
RCA universal 4 digit remote codes for RCR3273 RCR3373 RCR4257 and R55L8_Code_02. ... ICE, 1065. ILO, 1054, 1133, 1168, 1169, 1206, 1230. IMA, 1035.
Does SDTV = ATSC tuner - AVS Forum ' Home Theater Discussi
Dec 09, 2015 | iLO Televison & Video
My 32 in. ilo sdtv won't stop with the
Download the user manual to your ilo TV. For it with its exact model number. Refer the manual for details.
Jun 07, 2012 | Televison & Video
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
Black and white display screen
If you have an HDTV use HDMI or component to connect to get colour...if you have an SDTV and use the RGB cables unfortunately the PS3 will output NTSC signals for JApan/NA and your SDTV will accept PAL signals (EU). THere may be an adapter, but if you have an HDTV this problem should solve itself via HDMI/component cables.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
HDMI Port
you will have to look at the manual, but sometimes Audio isn't transmitted on HDMI cable,( I know it makes no sense). sometimes you will have to also use the digital optical audio cable, or SPDIF coax didital cable. I had to use the Di
As for your PS3 I had simillar issue, the PS3 doesn't Automattically adjust from analog, to component, to HDMI. If you get a signal thru the Reg RCA plugs, if you plug in the HDMI cable at the same time, then go to the system settings and change the type of plug you want to use, choose the HDMI, and the screen should flicker then show the signal from the HDMI, then just power off and/or unplug the analog cables, and you are using HDMI. hope this helps, if so thanks for the ratings
Mar 31, 2009 | iLO 3200 32 in. LCD Television
Playstation 3 not working with older model Pioneer AV receiver
If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
Hope this helps.
CABLE GUY.
Jan 01, 2009 | Audio Players & Recorders
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Ilo 32" SDTV
Use an S-Video cable and change the video mode to S-Video--should work fine. Good luck.
May 07, 2007 | iLO 3200 32 in. LCD Television
Sony Playstation 3 (PS3) Console Logo
166 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
