Question about Dell Dimension 4550 PC Desktop
Dell dimensio 4550
I dropped my computer on the top during transport. No, it no longer powers up. I checked all the hardware and it appears to be seated properly. I also tried a new power supply, but have the same problem. I do have a green led when I pull in the power cord, but the computer wont "boot" when I hit the on button. I have a Dell Dimension 4550.
  • viji2k Dec 15, 2008
    how can you be sure? is there a way to test the motherboard?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
You need to replace your motherboard. contact vendor
Posted on Dec 15, 2008
Dell 4550 keyboard failure
Hello, Sounds like you have either bad connection or keyboard, try powering down the computer and reseating the keyboard.If that doesn't work , replace.
Oct 27, 2011 | Dell Dimension 4550 PC Desktop
Tip
Dell Dimension 4550 Ethernet Driver Installation Guide Here are the steps on...
Here are the steps on how to properly install the Ethernet Driver for the Dell Dimension 4550:
1. First click this link to download and install the Intel Chipset Driver for your computer model.
2. After the driver installation is complete restart the computer.
3. Then click this link to download and install the Ethernet Driver.
4. Restart the computer again.
Other software downloads for Dell Dimension 4550 can be found here.
on Aug 20, 2010 | Computers & Internet
My Dell Dimension 4550 starts up and after about 30 seconds shuts off. It does not matter if I boot in safe mode or normal and I have disconnected everything but the monitor, keyboard and mouse.
If the computer shuts off completely like someone pulled the plug from the electrical outlet, it is probably your power supply. I would first check all the main cable connection from the power supply to motherboard. If the problem persists, swap out the power supply. Thanks.
Mar 18, 2011 | Dell Dimension 4550 PC Desktop
My Dell 4550 has a cold start problem. It works great once its been running, it has to warm up for 15 to 30 minutes before it completely starts up. I have tried everything, started from scratch. I...
Did you change the power supply ?- it is critical to the operation of your machine. Often if something is wrong with it,k it is not common for the machine to not boot up at all. Could be that until it gets warm some voltage is not up to par and the machine just waits till it is for it to operate properly.
Just make sure that your Dell power supply is not one of the older ones that had the wiring reversed and was not compatible with regular motherboards. Newer Dells are now compatible but older units can only use a Dell supply lest you burn out the motherboard.
Mar 18, 2017 | Dell Dimension 4550 PC Desktop
Dell dimension 4550 ethernet driver please
Dell dimension 4550 Ethernet Driver Installation Guide
1. Go here to download and install the Chipset - Intel driver.
2. Restart the computer.
3. Then go here to download and install the Ethernet driver.
4. Restart again.
Aug 20, 2010 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 Ethernet Hardware not working, cannot reload drivers.
Have you tried restoring your operating system? If not, please do so. There is a problem with operating system and the driver of your ethernet hardware. There might be a conflict on it.
Jul 12, 2010 | Dell Dimension 4550 PC Desktop
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
After reconfiguring my lap top's os, vista, I have no volume control installed.
Check your hardware device manager.
To access Device Manager, go to Start | Control Panel | System and Maintenance | System | Device Manager (Device Manager is located under "Tasks" in the left hand column of the "System" menu). A list of hardware will display like the one shown below.
Hardware you expect to find is not listed If you cannot find the hardware you expect to find, it is likely the hardware is installed incorrectly. You should power down your computer and locate the physical hardware on your computer. Verify it is installed correctly, and restart your computer. Once you have restarted your computer, Windows should automatically recognize the hardware and go through an installation process. You may be asked to provide drivers during this installation.
If you verify that the hardware is installed correctly but still does not appear in Device Manager, please contact the DoIT Help Desk.
A yellow exclamation mark appears next to your hardware A yellow exclamation mark next to your hardware means the device is recognized by Windows but is not working properly. This usually indicates a driver problem. Update your drivers by following the directions below.
  1. Right-click on the hardware and choose Properties.
  2. Click on the Driver tab.
  3. Click on Update Driver....
  4. Click on Search automatically for updated driver software.
  5. Windows will automatically look for updated drivers for your hardware. If unable to find any, you will need to go the hardware manufacturer's website and download new drivers.
A red X appears next to your hardware A red X indicates that the hardware is disabled. Right-click on the hardware and click Enable. Your hardware should no longer have a red X.
If you are still having problems with hardware after you enabled it, please.
Nedd more help try HERE
Feb 22, 2010 | Dell Audio Players & Recorders
My Dell Dimension 4550 won't recognize my CPU.
your problem is the same as trying to put a AMD3 into a AMD2 socket, yes it fits and yes i physically should be able to run it it but in reality it won't
Sep 26, 2009 | Dell Dimension 4550 P4 Socket 478B...
Download audio drivers for my dell dimension 4550
From link included select your version from (3) and sound card driver, download and install as instructed. I also recommend check out Dell support for 4550 PC at this link. Please rate me mysleuth
http://search.dell.com/results.aspx?spf=Dimension&ssysid=DIM_PNT_P4_4550&ssysn=4550&s=gen&c=us&l=en&cs=&ec=&ira=False&cat=sup&subcat=dyd%2F3&rf=all&evl=&nk=f&k=dell+dimension+4550&p=1&nf=&rpp=12&sort=K&~srd=False&ipsys=False&advsrch=False&p=1
Mar 19, 2009 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 PC Desktop Logo
154 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
