Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52130 won't turn on
TV clicks, but doesn't turn on, opened it up found a burn resistor at R14700.  I replaced the resistor, a 27k 1/2 watt, with a new one and same problem happened.  Do you know what is causing the burn out?  Got this tv from family and i'm not going to take a free tv to get repaired, i'd rather do it myself anyway. any help would be appreciated. thanks
  • forallthsin Dec 24, 2008
    A schematic would be very helpful, i'm not very harware oriented, but i'm not paying for someone else to fix a free TV.
    Thanks
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello forallthsin,
    If you can tell me which board the resistor is on, I might be able to help. This RCA uses the Thompson ITC222 chassis, but the numbering schema might be different, know the board and what the resistor connects to will help in locating the possible cause. So I need the following information:
    1) The board the resistor is on
    2) what the resistor connects to (just follow the traces and give me what connects to both sides of the resistor)
    I do have the schematic for this chassis if you need it. (please reply if you need the diagrams)
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
    Problem Solver:
  • 15 Answers
Check for bad connections on the flyback transformer
if they are bad you will see cracks in the solder
try resistor again
Posted on Dec 20, 2008
I have an Olevia flat screen TV. Lost the sound.
If the resistor is found burned; there should be a reason. IC short or some sort of that. Without rectifying the fault; if you replace it with an other resistor; it too will burn out, sometimes cause more fault to set. Check for the reason first. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 14, 2014 | Olevia 227-s11 27" 720p 1080i Hd Lcd...
TV turns self off during watching, also has darkened picture.
Do a hard reset to the unit, unplug the unit for at least 2 hrs and then turn it back on it should work fine.
Aug 27, 2008 | RCA D52130 52" Rear Projection Television
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
Smelled smoke and hot wires, tv went off and never came back on again. opened back and found only one small part looked burned out, ( broken and a little brown on the board.) Part number R14705.
Thats a 27K 1/2 watt Carbon Composition resistor 5% tolerance. You got deflection issues so a replacement resistor will most likely fail unless you discover whaich componenet on the deflection board caused the resistor to burn. The deflection boards have been discontinued for your model which has the ATC321 chassis. But you can get a remanufactured ATC321 deflection board from www.tvrepairworld.com
Jun 12, 2011 | RCA HD52W56 52" Rear Projection HDTV
Samsung lnt3242 has power but won.t turn on
Seems like you need to repair or replace the inverter boards you can get them here: CLICK if this helps please rate ;-)
for more information contact me here: http://tvtechwork.webs.com/
Oct 23, 2010 | Samsung Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Rca TV HD52W58
The number you gave for the resistor is incorrect. But I did find a R14705. This resistor is a 1/2W 27K ohm resistor. This part is also in the deflection circuit. This is not a good circuit to play in, and resistor do not burn up by them selfs. There is a problem somewere neir by. The part number for this resistor is 238958.
Jul 31, 2008 | RCA HD52W58 52" TV
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
Dark picture
If you can find it inside the set you need to replace R14700. This is the location number written on one of the boards. It is a 27K resistor at 1/2 watt. There was a bulletin by RCA on this problem
Dec 30, 2007 | RCA D52130 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
