Question about Sony Cyber-Shot DSC-T33 Digital Camera
"Turn the power off and on again" error message
Recently when I turn on my camera it beeps multiple times and I get the following error "Turn the power off and on again". I do this and the error message is still a constant. I am able to view pictures but the camera's lens doesn't open and this error stays up when in picture and video mode. I removed the SD card and battery and reseated them. Please help!!!!! Thanks-
  • 1 more comment
  • Hans Augenstein Mar 20, 2007
    Where do I take this to get this fixed?
  • Anonymous Mar 20, 2014
    When I turned the camera on, the lens would move in and out a few times, then the screen would show "turn camera off, then turn on again. I would, and would get the same thing. Now I just get a blank screen. I can, however, still view the pictures I had already taken
  • Anonymous Mar 31, 2014
    after i removed the sd card my canon cam are ok i downloaded my pictures to my laptop and then after i transfer all i insert again the sd card to my cam ang i open it its says lens error will shut down automatically.
I just had the same problem and I didn't know what to do and I found this post it was somewhat helpful. After I read this I disassembled the camera and I pulled out the lens cover up a bit its held by this white plastic inside be careful not to pull to hard because it looks like it could break easily. After I got the lens cover a little bit above the lens itself I powered it up and the lens MOVED! I tested it again and it worked. So I placed the lens cover back over the lens. And it all back together. It was a really quick fix it took me less than 10 minutes. I hope this is helpful to anyone that gets "Turn off the power off and on again" error.
Posted on May 01, 2007
    Novelist:
  • 154 Answers
You probably have a defective lens assy. When turned on lens has to move to certain position but because of broken gear or some mechanical problem it can not perform that funtion. Remedy is to disassemble the lens assy and repair the problem. Many time the whole lens assy are replace to repair the problem. normal repair charges for this kind problem is $125-200 in US depending on parts use.
Posted on Mar 19, 2007
SOURCE:
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
As soon as i turn it on it beeps and says turn the power off and on again the lens wont move in and out
I'm sorry that the camera display the eror: turn the power off and on again. If turning the power on and off again does not resolve the error message, try doing a power reset. Refer the URL for the information to reset a Cyber-shot® digital still camera back to original factory settings:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
If the issue is still unresolved, service may be required.
Jan 04, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
It put access than after it starts beeping and appears turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Turn on the camera.
Thanks,
KenSolutions
FixYa
Dec 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Lumix TZ3 keeps giving the same error message: "Please turn camera off and then on again"
sorry to tell you guys this but you definetly have lens faults, for you firwol i can say that you have a focus lens or image stabilizer fault, bob80 sand can definetly mess your lens around and is going to need a service. you can check the error codes. you need to do exactly what i say. turn camera off, mode switch to red camera selection, this has to be done quick, turn camera on holding the ois+ arrow up button, then quickly hold ois+menu+arrow left. post the error then i will tell you what is wrong.
Jun 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Access message
turn on
take hold of the end of the lense and gently pull and twist you may hear it click but dont force it then turn it off and on again this may solve the problem.
Mar 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error Message
hi, this err.related to ur lens.mechanical stuckup or dislocated this is repairable
Mar 25, 2008 | Sony Cyber-Shot DSC-L1 Digital Camera
Open Questions:
Sony Cyber-Shot DSC-T33 Digital Camera Logo
762 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
