2002 Chrysler Sebring Logo
Anonymous Posted on Aug 01, 2012
2002 Sebring. Too much static on radio
Can't set stations because none come in clear enough to stop on seek. Manually set stations are full of static. AM won't come in at all. CD plays fine.
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Aug 01, 2012
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
260214
Points
2321
Check your antenna with a test antenna sometimes the cable will fill with water or maybe it's just disconnected
  • Anonymous Aug 02, 2012
    Not quite sure how to do that. Can you point me to an online tutorial that will tell me what equipment and prcedure I should follow. Thanks for your help.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on May 14, 2009
SOURCE: 2001 sebring radio only scans. Wont stop on
Had this problem in mine, I would say try rebooting your computer in your Car. how ?1.)removing both battery terminals 2.) go in and turn the key (this will drain power in any circuits) 3.) turn key off 4.)then for around 30 seconds then reconnect battery.
Anonymous
  • 319 Answers
  • Posted on Jun 10, 2009
SOURCE: Radio 80c7e80b will not play, only get static on AM/FM CD Works
your radio is shot, and the cd and tape player still works. You have to buy a new radio if you want to listen to a radio.
tepfy
ROB
  • 858 Answers
  • Posted on Jul 20, 2009
SOURCE: factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
Robert Bivins
  • 192 Answers
  • Posted on Aug 11, 2009
SOURCE: car radio works on am but not fm
Your antennae is somehow disconnected from your radio. It may simply be that it has come loose from the back of the head unit. Or that your antennae mast is missing, or that the cable from the head unit to the mast is severed.
I hope this helps.
Sam
  • 3247 Answers
  • Posted on Jun 26, 2011
SOURCE: Why won't my 2005 chrysler
does it have fuel?
My radio has recently started to go into seek mode on it's own and I can't stop it when it starts.
New HD Radio Applications Seek to Fix System Flaws ...
diymedia.net/new-hd-radio-applications-seek-to-fix-system.../7560
Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Troubleshoot problems with radio stations in Windows ...
windows.microsoft.com/.../troubleshoot-problems-wi...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
My honda accord radio has been decoded but the volume is not functioning. why is there no sound and one cannot tune in to any station?
Was it just replaced? No tuning is the antenna wire wasn't plugged in. It would get stations manually, but with static. Not lock by itself. No sound could be a bad replacement radio or an amp. Check the amp fuse first.
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Radio wont set stations
hi, does the radio go back the standard settings when you turn off the key, if it does than try checking the fuse for the constant power supply as this controls the time memery and the settings for the stations, if not try holding the station button down for 3 to 4 sec
hope this helped
No wipers or turn signals on 2002 sebring
bay 15, 10 Amp (red Fuse) under dash at driver side door end (door marker "pull") ... U really do gota Pull!
2answers
How do I adjust the clock on my 2002 chrysler sebring lxi convertible
On factory radios and many aftermarket tuners...you need to remove all CD's, turn radio power off, find (set) or clock button generally sets face to show clock instead of radio...most use the seek and scan buttons to set hour and minutes...the owners manual also shows step by step. Hope this helps.
I just bought a 2002 Mustang GT and i am having a problem with the radio. when i am listening to the radio it will randomly scan and go to a different station. how do i fix this?
This means its in scan mode, it will go through all station until you stop it,make sure the scan button is not stuck, try to turn radio on and use the manual scan and dont use the seek button,
2answers
Car radio works on am but not fm
antenna is desconnected, find lead and reconnect .
1helpful
Problem with my Radio
mine used to do the exact same thing. it probably has to do with the singla strength. i just tuned in manually, then i just got an aftermarket stereo, but it does the same thing. it doesnt pick up every single station there is, clear or not clear.
2answers
Radio effected by brakes?
If this happens when the car is still you have voltage interference between brake light voltage & antenna. If this happens from motion check all wire connections, loose antenna wire, to antenna.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
