Question about Motorola Mobility RAZR V3
Can't remove the battery door
I just got this phone new, and I cannot get the battery door off the back.
I have pushed the gray release button, and done everything else I can think of, but the door is stuck tight.
Any suggestions?
    Brigadier General:
  • 7,752 Answers
Try a flat-bit screwdriver and open it up
Posted on Dec 26, 2008
I have omnia i910 samsung the screen froze and do noting
Try removing the battery from the back of the phone by removing the back cover. There should be some kind of button or latch on the back of your phone to push to release the back cover. Remove the battery and that will shutdown your phone. Put the battery back in, close the back casing, and restart your phone and everything should function normally. If you can't figure out how to remove the back case, just let the phone's battery run down and you should be able to restart it then also.
Mar 05, 2011 | Cell Phones
How to replace battery of blackberry phone
on the bottom back side of the phone there is a silver button that releases the battery door. This button does not really eject anything so while holding down the release button on the bottom back side of the phone you also need to pull back and away on the bottom of the battery cover.
Feb 12, 2010 | RIM BlackBerry Bold 9000 Smartphone
How to unfreeze samsung a736
Well first of all you can just remove the battery from your phone, the battery is located on the back side of your phone, Remove the back cover of the cell phone. Some Samsung phones have a plastic outer cover over the battery, while on other models the back of the phone is the back of the battery itself. Locate the release button or slider on the back of the phone. Depending on the Samsung phone model, the back cover or battery itself will slide downward or lift off when the release button is pressed or the slider is pushed upward.
Just insert the battery after 30 seconds, and then turn on your phone. hope this helps. Please post comment if further you have the same problem.
Good Luck!!
Thanks
Jan 12, 2010 | Cell Phones
Motorola motorizr z3 battery removal
On the back of the phone at the top of the battery door there is a little clip or button you push down while at the same time pulling away from the phone. The battery door should come right off. then you remove the battery by prying from the top of the battery outward.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Dec 14, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
How to open the battery
To remove the battery cover, turn off the phone first. Flip the phone to close it and then locate the back of the phone. Press in and then hold the battery door latch until it reveals the battery.
Please refer to this picture:
Thanks to this link for the picture.
Sep 29, 2009 | Motorola Mobility RAZR V3
HOW DO I EMPY
Remove the canister/dirt bin by pressing the button above the handle where it says Dyson. Next push the red or gray (depends on your model) trigger down whilst holding the canister over a trashcan. The bin door will open and release the dirt.
Jul 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
TRYING TO CHANGE THE DRUM AND NOT SURE HOW TO GET IT OUT.
Open the top door
remove the toner cartridge
unplug the DV unit plug on left side
move spring loaded gray lever to the rear and hold
grasp the vertical part of the DV unit , lift up and out
open left door
remove the waste bottle
push small gray button on drum and pull drum out
remove tape on new drum carefully
reverse procedure to install.
Jun 27, 2009 | Kyocera FS-3830N Laser Printer
I dont know how to remove my sim card
Remove the back cover and the battery - the Sim card should be under there.
Removing the back cover can be tricky - there is a button release on the top where you press it down and pull the entire back down. Once you remove the cover and the battery, you should see a metal flap that is covering the Sim card.
Jan 08, 2009 | Nokia 5300 Grey Cellular Phone
The Battery Door on my Sony Cybershot DSC-S40 won't open.
No easy solution except:
1. Remove all 3 screws from body.
2. Carefully wedge off the back half of body.
3. The back half is connected to the front half by a small cable. Don't break this!
4. The door has a hinge pin. Wedge up and remove this pin.
5. With small screwdriver, wedge off the door from top. Should pop out.
6. Apply small amount of oil on sliding areas.
7. Reinsert door. If still stuck, see step 5.
8. Reassemble camera back and screw down.
9. The reason for sticking is unknown, but door can still be removed by popping off as in step 5.
Nov 08, 2008 | Cameras
Motorola Mobility RAZR V3 Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
