Question about GE 31GT659 31" TV
I need to know how to access the verticle hold to adjust TV
I've got a GE 31GT659 31" which has been a great TV for the past 10 yrs, but now the picture has streched out vertically cutting portions of peoples heads and chopping off the score during sports. The Chasis # is CTX187CN2. Please let me know if you need more information.
  • 1 more comment
  • Jaime Garcia Mar 19, 2007
    Sorry the Chasis # is CTC187CN2. Thanks
  • Jaime Garcia Mar 20, 2007
    Sorry about the confusion, but I'm not the most technical person to describe the problem. What I think is happening is the Verticle size of the picture needs to be reduced to fit the television screen. I thought I would need to access the service menu to adjust the picture size, thus fixing the problem. Thanks for your help and I hope I explained it a bit better.
  • mpasheek Oct 02, 2008
    I do not have the orginal remote so everthing is done manually my picture stretches from top to bottom
    Genius:
  • 1,074 Answers
What do you mean that the picture streched out.this is a strange problem.as vertical problem does not strech it either have a line inthe middle of the raster, shrink both at the top and bottom of raster,lines run up and down on the raster.kindly explain your problem in detail then i will be able to help you.
Posted on Mar 20, 2007
  • Henry  Thomas
    Henry Thomas Mar 20, 2007
    llet me say that your set cannot be adjust check your transistors in your vertical sectionand the vertical ic you should be getting 30 volts comming out of the ic if you are not getting the right volts replace ic and transistors.i do not have a schematic at hand to give the position and part number.good luck
The phone is 5 yrs old but the receiver has crashed to the floor often. Now, the outbound sound apparently fades badly at times. Any suggestions?
you may be able to find a replacement handset on Ebay, they sell many such things...it probably is not worth trying to repair. Electronic devices have, and have had for many past years, a stipulation in the electronics area.
Anyway, try Ebay, keep looking, you may find a replacement.
finite lifespan, this is the reason for the introduction of the 'durable'
www.ebay.com
Jun 07, 2016 | GE Lands Phones
I have a 97 ford probe 4cyl. I'd like to adjust the tps with a voltage meter, but want to be sure I do it right! My check engine light isn't on but car idles rough. I've had the tps replaced in...
wheather your a2 .0 or 2.5 at idle key on engine off its is 0.7V to 1.1 V. you test it by doing a sweep, with your volt meter,voltage should increase with smooth throttle movement there should be no drop out or glitches and at wide open throttle you should reach 4.5 V , (***) wide open throttle
May 07, 2011 | 1995 Ford Probe
I have a craftsman professional model 10" cabinet saw, 3 yrs old. Been working great, just noticed blade is not square to miter guides. Where is adjustment Clfavia@yahoo.com
you can try going to managemyhome.com with your model number for an owners manual for the adjustments that you need. Let me know if you still need assistance.
Aug 08, 2010 | Craftsman 10" Table Saw
I have professional model, 3 yrs old. Been working great, just noticed blade is no square to miter guides. Where is adjustment Clfavia@yahoo.com
I don't have this saw, but my guess is the adjustment is underneath the table, holding the blade assembly. You'll have fun standing on your head trying to adjust it (loosen, tighten, try again) but that may be the only way. Good luck.
Have a GE 32GT740 32" TV.....How can I adjust the Verticle? I can only see part of the ESPN trailer line at the bottom of the screen.
the vertical deflection circuit of your tv has a problem.first try to replace the vertical ic..this ic can be found near the plyback or horizontal section It is a lenear ic with heatsinc..if nothing happens after replacing the ic ,,replace all the polarized capacitor near the ic and resolder the components at the vertical section...good luck please rate my help..
Jun 03, 2010 | GE 32GT740 32" TV
How do adjust verticle picture on Hitachi 46F510
You can adjust vertical height through the service menu, but i would recomed that you trouble shoot the vertical section as its probably a solder joint , leaky diode or something that is causing the problem. Often its bad solder at the vertical output IC itself that causes that sympton.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Image adjustment for GE 24GP65
Yes you can adjust the vertical size in the service menu, but you must be carefull when doing any horizonal adjustment as this can shut down your set .
Dec 16, 2006 | GE 24GP653 24" TV
Convergence Pattern
Hi, Your problem is in the convergance? Ever done the convergance on a proj tv? If you have, then you can find the convergance board behind the speakers as i recall IF YOU HAVEN'T DON'T START NOW. UNLESS,,, you have the service manual, or the knowledge to, and the test patterns neccassary, to do it. Each color has approx 10 adjustments for vertical deflection, and 10 for Horiz. IF YOU TRY IT and don't have any idea,, you WILL make it worse!!! It takes about 4 hrs to do it right for a qualified tech so ya better think of it as an all day affair! good luck
Feb 24, 2006 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
193 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
