Question about Dryers
Pulley replacement - Dryers
  • Dryers Master
  • 8,220 Answers
Idler pulley replacement is very simple. Here is a guide of various routings:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
on Mar 10, 2015 | Stairmaster 4000PT Stepper
92 buck century water pump pulley broke. how to replace
If the pulley actually came off the water pump then it was more than likely an integral part of the pump itself. Separate pulleys are usually attached with four bolts, and unless they were incorrectly installed they do not fall or break off. In this case the pulley was probably permanently attached to the pump and therefore the water pump itself will need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Feb 26, 2015 | Cars & Trucks
1997 acura tl crankshaft spinning freely, is this normal? Just replaced a/c compressor and the pulley is turning real slow. Belt is not slipping. The crankshaft pulley and a/c pulley/belt rotate normally...
CHECK SEE IF CRANK SHAFT PULLEY BOLTS LOOSE.IF CRANKSHAFT PULLEY LONG BOLT TORQUE IS FOR 130 FT LBS FOR 1.8L ENGINE. IF YOU HAVE THESE ENGINES CRANKSHAFT BOLT TORQUE IS 174 - 181 FT LBS ENGINES ARE 3.0L 3.2L 3.5L 2.3L 2.5L IF CRANKSHAFT PULLEY BOLT IS TIGHT.THE CRANKSHAFT PULLEY ITSELF BROKEN NEED REPLACING.
Sep 05, 2011 | 1997 Acura TL Series
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
A loose idler pulley threw the surpentine belt off - feels like bearings inside the pulley are shot.
will try to help. if the pulley has wobble,it's bad and in need of replacement. not a hard repair to preform. turn the bolt on the idler pulley thats bad counter clockwise,remove the bolt and pulley. replace with new pulley. you'll need to follow the belt routing on the hood of your car[a small decal that shows how to replace your serpentine belt] to replace the belt when you've replaced that pulley. if you do not have a diagram of your belt routing, make sure to ask where ever you purchase the idler pulley from. if not then post your question here and we'll be happy to help! i also suggest that while you're there replacing that pulley, you check all the other pulleys for wobble,just in case theres another problem you don't yet see. hope this helps and if you need further assistance please don't hesitate to post your question!thank you for choosing fixya.com
Nov 28, 2010 | 1996 Oldsmobile Aurora
Air contioner pulley making a lot of noise, is it easy to replace? Can i just replace the wheel?
Yes, you can just replace the pulley, or the clutch assembly. Are you sure it is the compressor pulley? The Squealing sound is normally caused by an idler pulley or a stretched belt. I would change the serpentine belt at the same time of changing either of the pulleys.
Jul 11, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Replace idler arm pulley
An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
Apr 11, 2009 | 1999 Dodge Intrepid
Pulley
Not really. This happened to me on my Stratus. I replaced the belt and the pulley. All was good. Look for play on the alternator flywheel/pulley. Other than that, you should be fine.
Mar 11, 2009 | 1996 Jeep Grand Cherokee
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
