Question about Frigidaire GLER331A Electric Dryer
Is there ANY way to disconnect the BUZZER on the dryer?
    Scholar:
  • 111 Answers
If it is the electro-mechanical type that has a electric coil with a metal strip over the top you can bend the metal strip away from the coil to shut it up. You should never alter the electrical design of any product unless instructed by the manufacturer to do so.
Posted on Dec 16, 2008
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    I have an older kenmore dryer. i want to disconnect the signal buzzer. can i do that?
    Since there is no switch to turn off the signal on the dryer, you would need to unplug the laundry centerand disconnect one or both wires that are connected to the dryer buzzer. The buzzer is shown as Key 38 in the first image below. The procedure for accessing the buzzer in this type of laundry center is provided in the second image below. You would need to insulate any wires disconnected from the buzzer with electrical tape or a wire nut to prevent them from shorting to the dryer cabinet.You should only conduct this procedure if you are completely confident in your technical ability to safely complete the process. Be sure to unplug the laundry center before accessing internal components. Internal metal edges can be sharp. Protective gloves are recommended.
    Apr 01, 2010 | Dryers
    Kenmore stackable washer dryer. Dryer buzzer is
    Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
    The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
    Apr 09, 2009 | Dryers
    I want to disconnect the buzzer sound on my dryer
    First of all if you can remove the back of the console to expose the timer and switches, there is usually a small block with 2 wires to it, and it has no knob connected, this is usually the alarm buzzer, remove 1 wire and tape it off,then try the dryer if no alarm wala.
    Jan 18, 2009 | Roper REX4634KQ Electric Dryer
    Dryer end of cycle buzzer
    disconnect the BUZZER wire from the Timer
    Sep 16, 2008 | Crosley CDG6000 Gas Dryer
    How to disable buzzer on kenmore dryer model#417.977962701
    Same problem! Any advice beyond taking the dryer apart and trying to find the wires to disconnect?
    Jul 18, 2008 | Dryers
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    Dryer buzzer
    Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
    Dec 18, 2007 | Kenmore 98702 Stacked Washer/Dryer
    BUZZER
    make sure timer is completely off. if it still buzzes you will need a new timer or disconnect the buzzer which is cheaper
    Dec 12, 2007 | Kenmore 659 Electric Dryer
    Buzzer sound
    The buzzer on most Kenmore dryers is a separate 115V AC unit, and can be unplugged (be sure your power cord is disconnected!)
    -- better yet, you might find an older style replacement door chime that is also a 110-115V unit, attach the wiring to this unit and have
    a rather melodious or at least just a pleasant "ding-dong" chime instead of the obnoxious buzzers that all the companies seem to be using today.
    Sep 14, 2007 | Kenmore 659 Electric Dryer
    Frigidaire GLER331A Electric Dryer Logo
    94 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
