Question about Datel Radio Communications
Datel Bluetooth Headset producing a buzzing sound
I have had the Datel's bluetooth headset for about 2 and a half months now and i was playing yesterday and the headset wouldnt turn on. When i left it to charge overnight and it did eventually turn on, i could hear everyone else speaking just as normal, but when i spoke my friends said all they could hear was a buzzing sound.
I then went onto the PS3's menu and looked at the audio headset settings. When i went on it i heared that the microphone was infact buzzing and there was no sound actually going through.
Hope you can help and please e-mail back shortly.
Many Thanks
Oli
SOURCE: Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Posted on Jul 02, 2007
SOURCE: Increase microphone volume of H350
hi i have h350 i cant pair it to my phone can u help me?
i have the verizon lg vx9900
Posted on Apr 28, 2008
SOURCE: pairing my headset with ps3
forget pass key for madcatz
Posted on Dec 31, 2008
praky16
  • 744 Answers
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Posted on Feb 08, 2009
  • 94 Answers
SOURCE: No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Posted on Dec 03, 2009
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
Use your Bluetooth Headset with your Blackberry
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
Bluetooth passweord for datel headset please.....
dan_4ley
I do not know if you need the PS3 manual so I included the link below. How the code is "0000".
http://www.datelcustomerservice.com/product_pdf/PS3%20-%20Bluetooth%20Wireless%20Headset.pdf
Let me know if you have any more problems or questions.
Issken
Dec 25, 2009 | Datel Radio Communications
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My bluetooth pairs but won't connect
Hello krissylucas,
Erase the Bluetooth Headset's name from the bluetooth pair devices list on the phone .. and reset the bluetooth headset then try to connect again
Thank you for using FixYa.
Apr 09, 2009 | Eforcity Motorola Bluetooth Headset H500...
Motorola H700 Bluetooth connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Apr 01, 2008 | Motorola Mobility Bluetooth...
I loose BT connection after one song
Does the motorola headset make decending tones when it disconnects? If it does, you are listening to your music using the Headset bluetooth profile rather than the High quality audio one. You will need to change the way the device is paired to the phone. Try pairing it as bluetooth headphones or bluetooth high quality audio, rather than a bluetooth headset. Once you have done that, you can pair it as a bluetooth headset too, as the motorola headset connects to 2 bluetooth devices, or in this case, one device, with two profiles. To use the headset profile, press the left M symbol once, and the headset will play a sound to indicate connection as a headset. If you press it again, it will revert to High Quality Audio profile, and you can listen to your music, and even skip/pause it!
Apr 26, 2007 | Motorola Mobility HT820 Wireless / Cable...
Radio Communications Logo
120 people viewed this question
Top Datel Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Datel Radio Communication Expert? Answer questions, earn points and help others
