Question about Pioneer PRO-99 TV
Pro 99 My PRO 99 has a blue wave going across the whole screen. I thought maybe convergence ICs? Any suggestions? tvmangene@hotmail.com
    Scholar:
  • 150 Answers
Sounds like convergence outputs. Possibly some biasing resistors.
Posted on Jul 07, 2007
SOURCE:
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Black screen with 3 colored lines going across
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a blue and yellow wave across the top of my tv its a hitachi 53udx10ba
Ur convergence it dead.U know how to solders?Must replaced 2 Convergence ICS and all it resistors.Tries Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 17, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Pioneer Pro-118
you need two STK392-110 convergence Ics they are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Nov 30, 2008 | Televison & Video
Blue wave across screen
Just click below for convergence repair kit;
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
I have a older model
You will need to replace both convergence ICs. This is a simple common repair for all projection TVs. If you would like I can post a link where you can order your ICs and they provide step by step instructions on how to remove the old and install the new ones.
Mar 28, 2008 | Pioneer PRO-119 60" Rear Projection...
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
www.imageperfection.com
Jan 11, 2008 | Pioneer PRO-1009W 57" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
