Water will not drain
I have a Frigidaire FT645RHS front load. The water will not drain from the tub. I also need the schematics of the machine
  • karamad Dec 18, 2008
    Easy fix. Thanks for the help.
    Sergeant:
    Novelist:
  • 327 Answers
For exact schematics please click this link
http://www.applianceaid.com/frigidaire_frontload_washer3.html
Posted on Dec 15, 2008
How do I access the drain pump on a Frigidaire Affinity front loading washer?
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 01, 2011 | Frigidaire Affinity ATF7000E Front Load...
Where is the drain pump filter on the Frigidaire front load washer?
You will need to remove the back of the machine. Then, look on the bottom of the tub, you will see a drain hose that you need to remove from the tub and there is a filter inside of it.
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
I have an older washer top load frigidaire gallaxy and water is spilling on floor and tub is spinning but water wont drain all the way
you need to check the drain pump for anything that may be obstructing the flow of water.If the water is coming from the bottom of the tub the you mif=ght have a bad tub seal.
You can use a screwdriver and push the tabs in on the lid to lift up the lid and remove the two screws from the front panel on the bottom and remove the front panel. and check all the hoses from the tub and the drain pump.if there is still
Nov 06, 2010 | Washing Machines
My ATF700ES Washer does not spin the water out of the tub
Fist you need to know if the machine is draining the water.
if not..... have the drain pump checked and the clean out checked . Front load machines will not spin unless the water is drained.
If it it then the water level sensor needs to be ckecked.
Sep 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Tub won't move
could be motor, control board, motor controler
Apr 10, 2008 | Frigidaire GLTF1670A Front Load Washer
Water filling tub on washer
First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
Jan 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
