Question about Sumvision Sempra PRO Digital Media Player
Sumvision cyclone multimedia player firmware lost
Hi, I was just upgrading the firmware when the power to the house went out. I now seem to have lost all firmware. Is there any way to restore it using the PC?
  • 2 more comments
  • alhayes Dec 16, 2008
    Does anyone know of a button combination which would restore the default factory settings on my Sumvision cyclone multimedia player?
  • Anonymous Jan 12, 2009
    same problem here....lost the lot......have menu page , does nothing after that ...if anyone knows. please help...dangreen67@btinternet.com....if discs or anything needed will gladly pay.....Danny
  • carlos_123 Jan 26, 2009
    I can't see the firmware upgrade option in the setup menu - any ideas?
  • na_das Mar 19, 2009
    I don't see the firmware update option in the setup menu!
    is there any other way of doing this?
    Problem Solver:
  • 6 Answers
Cx3200:
SUMVISION CYCLONE 1 Tb REC/PLAY HDef Media System :
If After Formatting Hard Drive for 1st Time Your Screen Goes Blank and after Cyclone Logo Screen has Loaded:
Press TV System Button on Remote Control a few Times , and you should be able to view the Menu Setup Screen and Adjust for Pal / ECT::
The Cyclone Sometimes Jumps to the High Definition Output Setting and you Need to Do this to Adjust the Output for your TV ect:
I Had This Problem and I Phoned Envizage for the Solution which Worked , and i Have Restored my Menu :
Posted on Jan 28, 2010
  • 16 Answers
Http://www.envizage.com/g/36586/downloads.html
Heres the link to the firmware update.
Posted on Feb 13, 2009
  • minotaur3868 Aug 30, 2010
    Nothing found at that location!?
  • 3 Answers
Take out the hard drive.
Format it using fat32 either by usb connector or install it in a pc.
Put new firmware on the hard drive. do not put it into a folder.
Check player for a button battery if there is one installed remove it and leave out for about 10 minutes.
Replace the button battery, replace the hard drive and boot it up.
Hope this helps.
Posted on Jan 10, 2009
Drive should be formatted in FAT32. This is more preferrable than NTFS
Firmware for Cyclone is
_mpd1100_ (do not rename)
check google for cyclone firware upgrade to get latest firware file as named above
Drive needs to be blank.
Transfer extracted file to the disk
Use Setup -> Firmware Upgrade. Confirm after F/W compare.
hope this helps
Posted on Jan 13, 2009
  • 1 more comment
  • craigie05 Feb 21, 2011
    Sorry to seem a bit thick here but how do i get the Cyclone to read the USB stick with the firmware onj it as there is no setup facility on the Cyclone box? i have the media centre box with Firmare _mpd1100_ (latest) all ready to go on .. cheers
    Also, mine used to stick allot,, very unresponsive and thrustrating so i plugged the box into the laptop, took all the movies off it and formatted the 500GB HDD and then put 4 equal partitions on it and then transfered all my movies back onto the 1st partition (36GB worth) and it seems to work fine now ... i dont think it likes reading the 500GB as a whole drive but prefers smaller partitions - all i need now is to updatee the firmware - i have the .bin file (mpd1100 latest) on a USB pen drive but cant seem to find a setup option for the box to read from the USB to update the firmware ..any suggestions would be much appreciated
  • MackHenry Feb 21, 2011
    I think they all stick if you use a non compressed video format or use pause and fast forward alot. I play divx converted video from the start and it works every time. I know this is a limitation but its a great way to keep alot of stuff in one place that can be accessed quickly. I never had the problem you mentioned maybe it needs to see the whole drive formatted in fat32 with the firware file loaded before it will run setup. I never used a pen drive just usb to my computer
You will find that your PC has far more video codec support than your media player..
If your avi's are playing out of sync,I would recommend re-encode them using winavi etc...
I find BRRip to be the best media to play on these media players and never have audio sync issues...hope this helps
Posted on Jun 23, 2010
I have the same problem, I tried to update the firmware, the screen went blank, I left it for around half an hour and realised nothing was happening. Since then it won't return to the menu and just hangs on the logo screen. Any idea on how to reset the firmware? There is no battery to remove and no obvious jumpers to clear the settings.
Posted on Mar 13, 2010
Just bought a cyclone multi media player when i watch video playback through tv the audio is out of sync when play back though pc its ok can you help please ??
Posted on Jun 27, 2009
Hello peoples,
I seem to also have made the school boy error of having a secondary partition in NTFS which has resulted in the voice/video sync issue. I intend on formatting the drive in FAT32 and re-installing the latest firmwear.
Any body have a link to the latest firmwear I have the basic none HD Sumvision Cyclone 3.5" HDD Media Player
Posted on Mar 16, 2010
  • 4 Answers
Look in your user manual it says :- NOTICE: WHEN YOU UPDATE, DO NOT SHUT OFF THE POWER, IF NOT WILL BE DESTROYED THE EQUIPMENT. so it is no good now
Posted on Jan 08, 2009
How to find internal storage on cyclone micro 3
There is a "Firmware" update to Cyclone micro 3 .This can be downloaded from Sumvision web site :-
http://www.sum-vision.co.uk/productinfo/micro3b/micro3b.asp
When downloaded copy the file on to a Memory stick or card and click the USB entry or memory card entry on the main menu, and the Cyclone will update itself .
There should now be an entry on the main menu for "internal storage"
Feb 19, 2013 | Sumvision Cyclone Micro 3 Media Player
SUMVISION CYCLONE MICRO DOES NOT SHOW ALL MOVIE FILES ON EXTERNAL HARD DRIVE
Some video formats may be incompatible with the player.
Your laptop probably has more codecs, so more compatibility.
Try a program like Video Inspector to see formats of different files.
Nov 20, 2017 | Sumvision Cyclone Micro 1080P Upscaling...
Sumvision cyclone not working
i am having the same problem.
can anyone explain.
Power tries to turn on but fails to come up with screen that says HELLO.
It just flickers on for a second and then powers down straight away.
Apr 26, 2010 | Sumvision Sempra PRO Digital Media Player
Cyclone media player firmware problem
Sumvision Cyclone Latest Firmware Update
Latest release of firmware to fix customer who may be experiencing "menu" problems or large HDD problems:
Please download the .zip file from the link below:
http://www.digitalpromo.co.uk/images/cyclone%20upgrade.zip
Then follow these easy installation instructions:
Info: Hard drive must be either new or contain very little data for this update to work.
1.) Extract the file
2.) Put it in the root of the HDD
Note: Dont change the file name, dont put it in a folder
3 .) Power the device on, go to the "setup" section, and click the upgrade firmware
Regards
Sep 03, 2009 | Electronics - Others
Firmware update issue
The firmware file isnt a VLC file it is a .bin file you can get the file off sumvisions website http://www.sumvision.com.cn/drivers.aspx it is the second one down.
Jun 29, 2009 | Sumvision Sempra PRO Digital Media Player
Firmware for cyclone mmp
http://www.sumvision.com.cn/drivers.aspx Its the second one down where it says firmware when its downloaded extract it onto the hard drive make sure there isnt much files on the hard drive then connect to tv go to setup select firmware and press play to update.
Jun 16, 2009 | Sumvision Sempra PRO Digital Media Player
Can't see Sumvision Cyclone HDD on PC
see this link
http://docs.google.com/Doc?id=dgcfqncj_0cnqvx5gt
Jan 27, 2009 | Sumvision Sempra PRO Digital Media Player
Sumvision Sempra PRO  Digital Media Player Logo
13,205 people viewed this question
Top Sumvision Audio Players & Recorders Experts
Paul Bade
Sock Puppet
Clive
Clive
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
