Question about VeriFone PRINTER 250 RS232C INTERFACE
I have a VeriFone Printer 250 and the paper will not feed and the power light is blinking....I have turned it off and on and it still does not work. HELP!
  • frontend Jan 26, 2009
    i have the same problem!! i left one machine unplugged overnight and it magically worked the next day but that wasn't the case for the second one. i have no clue about why it was happening, there doesn't seem to be any event to spur this!
  • Anonymous May 22, 2009
    same problem
I had the same problem - I took out the ribbon and tightened it, put it back in and replaced the cover securely. Then I disconnected the power and turned the switch off. I plugged it back in, switched it on, and the problem was gone.
Posted on Jul 20, 2009
Printer begins to randomly feed paper and will sometimes feed two feet or more of paper without any transaction. If you tear off the paper, the VeriFone will continue feeding paper without stopping. We...
It's because of power issue You have to disconnect all the cables and clean make sure no dirt Connect the printer first and power up the register If still the problem persists you need to replace some files by doing a dialin
Mar 17, 2011 | VeriFone 900 Printer
Power light blinking paper wont feed through
Unplug the power cord from the printer (top left side). Hold the paper feed button while plugging the cord back in.
Jun 29, 2010 | VeriFone 900 Printer
Verifone 900 blinking power ligh
On the P900 printer, this blinking light always means "service". The P900's are notorious for software issues after they have aged. Every time we encounter this issue (very common), the only solution is to send it in for repair (usually ~$75).
Apr 23, 2009 | VeriFone 900 Matrix Printer
Credit Card Printer P250 prints too small
I had a similar problem ... printer printing receipt just like when printer test conducted. I turned printer off, pressed/held paper feed button, turned on, let test run, then shut off. This didn't work ... so I disconnected terminal cable from printer (printer turned off) and reconnected. Printer now works fine.
Dec 05, 2008 | VeriFone 250 Matrix Printer
3750 fails to complete transaction
it needs to reprogram the machine
erase all of Memory and cache
ask your processing company, build NEW terminal file
and install fresh one.
Sep 25, 2008 | VeriFone Omni 3700
Inserting Paper into Verifone Credit Card machine
I do not have a pictur eor video but it is not difficult. Open printer door, place paper in printer with the paper coming out towards the keys of the terminal from underneath the roll. Pull slacked paper over keys of terminal and shut printer door.
Aug 21, 2008 | VeriFone Omni 3700
Verifone 250
The Verifone 250 doesn't have keys. What are you talking about?
If you mean that it just isn't printing, verify that the ribbon is properly inserted and the impact setting is correct.
May 14, 2008 | VeriFone 250 Matrix Printer
PRINT PROBLEMS
Check your power supply. I believe the Current is rated at 2 amps. If you have a supply that is generating less than that it will result in having this same issue with the printer.
Mar 11, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Verifone 250 printing letters and numbers will not stop
The letters and number it is printing is the self test print mode. Normally to run the self test you would turn the printer off, then hold down the feed button, then while holding the feed button, turn the power back on. It sounds like your feed button may be stuck.
Mar 10, 2008 | VeriFone 250 Matrix Printer
309 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
