I need to turn on my help and support server - Computers & Internet
  • darlenedeemo Feb 09, 2009
    monitor wont come on
    Scholar:
  • 40 Answers
I believe you mean help and support service. In which case:
1> Go Start -> Control Panel -> ( under Performance) Admin Tools -> Computer Mangement
2> After opening the computer manager, you'll see three explorer branches on the left of the util, the last will be Services and Applications. Click the + next to it to expand it if needed.
3>Under Services and Apps, click on Services in the left explorer panel.
4> It should show several services to the right hand side. Click anywhere on a service and hit "h" to fast navigate until you hit Help and Support.
4.1>On the same line as the name, there should be an entry saying what startup mode it is in - Auto, Manual, or Disabled. If it is in auto, it should already be running, and the "Status" field should say "Started" - if it isn't started, it will be in step 5.
4.2If the service is on Manual, it wont start itself - if you need it in the future, you should right click on the entry and then Properties.
4.2.1>Once in properties, make sure you're in the "General" tab. Once there, a pop-down field next to a label of "Startup type" is where you want to change it to Automatic.
4.3> If the service is Disabled, you will need to follow step 4.2, and set it through Properties to either Manual or Auto.
5> Right Click the entry for Help and Support, and click Start. This should start the service.
Have a nice day and please rate. Thank you.
Posted on Dec 15, 2008
Cash register express
hi Lloyd,
need more info about your setup to help you. is this a stand alone station or connected to a server? your question wasn't clear about this.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Mar 30, 2014 | Pc America Computers & Internet
Hi, My HP Proliant DL360 G3 server just doesn't bootup due to the following error"CUP Zone Fan Assembly Failure Detected". When I turn it on, it emits continuous beeps and then turns...
Check and Clean Processor FAN and all cooling Fans inside the server.
Check the cable connectivity of the CPU Fan on the M/B.
Update server with Latest BIOS firmware.
Aug 02, 2011 | HP Compaq ProLiant DL360 G3 Server
Cant turn on Wifi using fn + f2 please can you help
The problem would be that the server would not be switched on for use of others without password . Turn the server's wifi security off by setting the server's website and then try to connect to internet .
Dec 14, 2010 | Computers & Internet
Sir my canon 3300 error e00000-0000 pls help me
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
plz do rate solution if helped
Nov 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I forgot my sql server password, and i need to get the sql sa password back, how can i retrieve my sql sa password? its SQL server 2005. Any advice is ok, i dont want to reinstall the SQL server, Thanks in...
Lost or forgot your administrator/user password for Microsoft SQL Server?
If so, turn to help from AnyPasskey SQL Password Recovery, which is a professional program enables you reset administrator or user password for Microsoft SQL Server instantly regardless of the length, complexity, language and encoding of the password set before. As long as you got AnyPasskey SQL Password Recovery and master.mdf file, you could reset SA password on any authorized PC in minutes without the installation of Microsoft SQL Server. What's more, this featured-in tool supports all versions of Microsoft SQL Server and Microsoft SQL Server Express perfectly. 6_21_2012_1_55_07_am.jpg
Sep 15, 2010 | Computers & Internet
Need to find my dchp server for wireless adapter for networ
Generally, you don't need to configure much to use a DHCP server - they're designed to automatically respond to requests for configuration information, and devices dependent upon them are designed to automatically make such requests. If you have two TVs working fine, your DHCP server is probably working, so you should look at the third TV to determine why it's not connecting. How are the TVs connected to the network? Contact the manufacturer of the network adapter or look for FAQs on their Website to see if they can help you. If it turns out to be a hardware issue, the manufacturer will be the best source. If it turns out to be a network configuration issue, MaverickSolutions.biz would be happy to help you further.
Jul 21, 2009 | Computers & Internet
IBM Server Information
It depends on what you do with the server, a server may be just another computer or a great help.
You can use your server as a Web Cache server, this means that the server will storage all the webapges your users access, so, when somebody wants to open a webpage the server will download only the updated parts of the webpage, that will save time and the users will think everything is faster.
Yet a server won't give you a faster internet conenction per se, it just optimized your resources, a server can also be a firewall or an antispam, so your network won't have undesired traffic coming from internet, so less trafic, faster network ^_^ .
Yet again, if you only buy a server, then plug it into your network and turn it on does not make anything. You will need to install/configure diferent solutions (sometimes you will need to buy them).
I recommend you to go with Linux, it is free, open source and there is plenty of documentation out there.
Mar 12, 2009 | IBM Netfinity 4000R 8652 Server
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
