Question about Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac7202 Today i was hooking up my kenwood kac7202 amp to a boston G5 and when i was hooking it up it turned on and every thing but it was hittin good then it stopped and my led light is on but there is no sound can somebody pleez help
  • Anonymous Nov 29, 2008
    SERA QUE EL KAC-7202 STEREO/MONO ME LEVANTA 2 WOOFER PIONEER DE 12" EL TS-W307D2
  • 62 Answers
Unhook the Speaker leads from the amp and check for resistance between the two on the amp... it should be 0... now reattach the speaker wires to the amp and check the resistance...depending on the load at which the amp is stable it should be more than 1 ohm at the least...2 ohms on most amps. If all that checks out, check your pre amp inputs. Maybe something came loose behind the deck.
Posted on Mar 25, 2007
I have a kenwood excelon (794, I believe) with 6 pre-amp outs. I'm currently running a boston acoustics gt2-125 amp powering 1 alpine swr-t12 shallow mount, type-r sub (12"). I have 2 alpine...
This answer will require a very detailed technical solution, therefore I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
Apr 24, 2017 | Clarion EQS746 Equalizer - 7-Band In-Dash...
I have the kvt 617 I have great audio when listening to radio nut anythig else I only have subs it started doing it when i first got it and then it quit and know it is doing it again any idea?
High end kenwoods have a setting, where you can turn off the internal amp in the head unit, if the sub is the only thing that has an external amp hooked to it, and it is playing, that may be your problem. Also, if one of the speakers hooked directly to the Kenwood has a short, bad voice coil, or contacts touching metal, that can cause the amp in the Kenwood to go into protect, and you will loose sound to all the speakers.
Aug 18, 2009 | Kenwood KVT-617DVD Car DVD Player
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Aug 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Reciever
Since Kenwood makes a lot of amps, I can't be specific. Check to see if speaker (A/B) is switched on. Make sure "mute" switch is off. If useing tuner, make sure to hook up AM/FM ant.
Apr 14, 2008 | Audio Players & Recorders
Kenwood amp
how big the amp dont forget those thing take lots of juice you need a big wire front battery to amp when the engine running it should be 13.8 to 14.5 volt if anything less than that battery wont get the charge up and check for good ground cheers and dont forget to rate this p.s any other question about our charging system or anything else dont hesitate im ear
Jan 18, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
My Kenwood KAC 9152D 1800W AMP acting funny
Sounds like you got the wrong speaker load by either parralleling some speakers or else you bridged the outputs in such a way to create the wrong speaker load or maybe all of the above. In short, it sounds like you have blown at least one of your output channels and its time for a trip to the repair shop. I suggest you disable your amp at once so that it doesn't do any more damage to itself.
Jan 09, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
50 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
