Question about HP Officejet Pro L7680 All-In-One Printer
Error code 0005FBB6
Can you please tell me what this means?????
  • 4 more comments
  • dfaria Dec 15, 2008
    can you tell me what this error code is 0005FBB6 please?????
  • Anonymous Dec 16, 2008
    Funny - I have the same problem on the same day!
  • Anonymous Jan 08, 2009
    I have this error when I connect a network cable to an HP L7780 printer.
  • NEW5STAR Feb 06, 2009
    SAME PROBLEM - AFTER POWER OUTAGE IT ASKS TO TURN OFF THE COMPUTER PROPERLY - SPITS A SHEET OF UNUSED PAPER HALFWAY AND ASKS TO TURN OFF AGAIN THE PRINTER BY PRESSING THE ON/OFF BUTTON. A NEVER ENDING CYCLE - DRIVING ME NUTS! CANNOT WORK - WHERE CAN I FIND THE SOLUTION TO THIS PROBLEM?
  • later517 Mar 06, 2009
    I have the same problem and HP can not fix it I called amex and put in a claim for money back and told hp to blow
  • Anonymous May 08, 2009
    I have an Officejet L7780. HP Support told me to try pressing # and 6 simultaneously while plugging in the printer. Several attempts later nothing.
    Pressing # and 3 worked for me to reset the printer.
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Cloud Striver
If you have further questions email cloudstriver@gmail.com
Posted on Apr 20, 2009
Fix without reset:
I had the same error. When you press the power key, the printer reboots and gives a warning message for improper shutdown. For some reason, it is not fully going through the normal shut down procedure before the reboot, and apparently not clearing it's memory. Solve this as follows:
  1. Press the Power Key and allow it to reboot.
  2. When you get the improper shutdown message, hit 'OK'.
  3. Right after, once you see the normal status screen and the printer starts making it's funky warm up noises, press the Power Key once again to invoke a normal Shutdown. The screen should say "Shutting Down" at the bottom as it goes through the normal sequence of clearing memory, etc.
  4. Once it reboots, resend the job to the printer, - everything should now be A-ok!
Posted on Mar 26, 2009
  • 3 Answers
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information. Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Mar 18, 2009
Fix HP Printer errors or get support from HP printer support helpline, take help on error code 0005fbb6
http://www.customerhelptech.com/blog/hp-printer-error-code-0005fbb6
Posted on Dec 08, 2018
The solution 1-3 doesen't fix my problem.
It could be a problem with the fast or quick printing mode. To fix it, settings on normal mode and after printing of some papers in this made try the fast or quick mode again.
Posted on Feb 23, 2010
2 Suggested Answers
gewiz
  • 1355 Answers
SOURCE: can you tell me what this error code is 0005FBB6
Can I ask what is giving you this error code ?
Posted on Jun 13, 2009
How do i unscramble dudees. I've tries all the solutions but couldn't come up with anything. Any suggestions Helen
can you please tell me what dudees means please.if you put it back on fixya saying what it means someone might be able to help you out.
Dec 11, 2016 | Sewing Machines
Whirlpool Duet Sport Error Codes
HI,
Can you please tell me what error code your getting so that i can tell you what it means..
Waiting for your reply..
Apr 21, 2008 | Washing Machines
Hi please can you tell me what error code drying 4 means on neff wadher dryer v438oxogb please? Many thanks
By chance are you getting error E04 ? If so that means
(temperature sensor) shorted or open circuit
  • Check wiring
  • Check wash NTC
Nov 08, 2016 | Neff Dryers
Boot menu not working
Do you mean the Start menu? Or do you mean the PC is just not turning on at all? We need more info to give you a good answer. Please tell us more, and tell us what you did or what happened just before that also, please. It will help us a lot. :)
Oct 21, 2013 | Dell Vostro 1500 Notebook
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
Please, I bought a used toshiba 2060 copier, if I put it on this is what showed on the screen "SLUIT ZIJKLEP BENEDEN" could you please tell me what it means. Again could you show me how to change th
OOOOH NOOOO! You wasted your money sorry to say. The 2060 is an analog that is obsolete, a good majority of the parts in that machine are unavailable. I would cut your losses.
Jan 22, 2013 | Toshiba 2060 Copier
Hi please i ask you what is the meaning convention and alphanumeric and i want to this both of words meaning in english did you now? and please i wait you answer please tell me the correct answer because...
Convention has several meanings:
  1. A large formal assembly (ex. political convention)
  2. Something regarded as a normative example
  3. An international agreement
  4. Orthodoxy as a consequence of being conventional
  5. The act of convening
Alphanumeric refers to combination of alphabetic (Latin letters) and numeric (Arabic numbers) characters.
If I helped you, please rate my answer :)
Sep 07, 2011 | Computers & Internet
On my Photosmart D7460 HP printer, the error code 0005FBB6 keeps coming on the screen saying that I have not powered down properly... not allowing me to print and setting off all sorts of flashing...
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
Mar 26, 2011 | HP Photosmart D7460 Printer
HP Officejet Pro L7680 All-In-One Printer Logo
6,887 people viewed this question
Clive
Clive
