Question about Olympus Camedia D-395 Digital Camera
I can only go into quick mode...
Okay, My camera was working perfectly up until the other day. Normally, you'd slide open the cover to turn it on, correct? Well, I tried to do so the other day, and it wouldn't turn on. So I put in brand new batteries. Still, it wouldn't turn on. But then I realized that the quick view button worked. That button just sent me to quick mode.Once I'm in quick mode, I can hit the OK button next to it. That brings me to the mode menu option. Those are the only two buttons that work, and I cant take pictures all together. Could somebody help me? and try not to sound all smart, I'm only 15. Haha. =]
  • 75 Answers
This sounds just like the problem experienced by mmmm. The link under the barrier is probably broken and needs to be replaced. This repair should not be terribly costly since you most likely won't need major parts.
Posted on Mar 25, 2007
Shutter is not opening in PL-90
A stuck automatic lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it:
METHOD 1:
Point the camera straight down into a vacuum hose (while the vacuum is on) and tap it around the insides. This will help to **** the dirt out instead of pushing it in further like compressed air might do.Also turn the camera on and off constantly while doing this.
METHOD 2:
1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible.
2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degrees to clear out any debris that may be in there.
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work then it may be necessary to open the lens barrel to access the lens cover mechanism.The lens cover mechanism is usually accessible for many cameras without needing to open up the camera case.
May 31, 2011 | Samsung PL90 Digital Camera
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Auto focus not working Kodak V803
is the setup shoing that it is on MACRO? if so turn MACRO off
Jun 20, 2009 | Kodak V803 Digital Camera
I have a 3 year old Sony DCR-DVD202E Camcorder which has worked perfectly up until yesterday, when the lens cover refused to open. Other thsn this the camera powers up normally and the LCD screen shows a...
Sounds like the gears are stuck, the motor is bad or that the potmeter is bad. The only way to fix this is that the camera has to be opened. If you are sending it to repair make sure that it is not to costly to fix. Most times spending a hundred extra dollars would buy you a new camera then repairing the old one.
Jun 09, 2008 | Cameras
Lense will not close properly
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Cover open, camera does not turn on.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Cover open
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Olympus Camedia D-395 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
