Question about Keurig B70 Coffee Maker
The coffee tastes like plastic
Purchased new Keurig B70 Platinum Single Cup Brewer and the coffee has a very strong taste of plastic. I have run baking soda and also vinegar through the machine and it still tastes the same.
  • 1 more comment
  • mmabsb Jan 10, 2009
    I have the same problem and contacted Keurg and was told that the plastic taste is caused from sitting in boxes waiting to come to the U.S. I was told to clean the resovoir with soapy water and then to run vinegar & water thru the coffee maker, of course without k-cups. I have done this on two different days. Today it seems to be improving. They also suggested putting the water resovoir in the dish washer, but do not let it go thru the dishwasher heat cycle. With a little bit of effort and patience, I think this may work. Good luck. If you have no success call Keurig Customer Service. We can't be the only customers experiencing this problem.
    OSU Buckeye
  • Anonymous Mar 05, 2009
    I am suddenly having the same problem with a strong taste of plastic. It doesn't matter if it's coffee or tea. It was just fine for months.
  • Anonymous Mar 16, 2009
    I have several Keurigs and have experienced this problem when I do not use it frequently. If you run 5 cups through without a pod it seems to improve.
    Problem Solver:
  • 7 Answers
Get a new one
Posted on Aug 13, 2009
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
  • 5 Answers
SOURCE: Slow coffee stream and smaller brew size with B70
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
Posted on Aug 12, 2009
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
SOURCE: where is the Serial number location on keurig b70
Pull the drip tray out and the serial number is on a sticker where the tray slides into the main unit. You have to get down low and look straight in and you will see it.
Posted on Dec 13, 2010
  • 3 Answers
SOURCE: Coffee tastes like rubber / plastic - brand new
This really worked - I'm surprised they don't include these instructions in there getting started manual. I was thinking I had made a big mistake but just now brewed a great cup of coffee. Phew!!
Posted on Aug 04, 2011
How do I remove the bad Plastic Smell & Taste from my Keurig B70 Platinum coffee brewer?
That should not happen. Return for a replacement. The heating resovour may have factory material in side the unit.
Jan 21, 2013 | Keurig Platinum B70 Coffee Maker
Coffee maker never makes proper size, almost always have to run it 2-3 times to get even a small mug. Intermittently shuts off completely, have to turn it on in back. (B70)
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 02, 2011 | Keurig Platinum B70 Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
also clean the holes at the bottom of the k cup holder
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
I have the platinum Series Quiet Brewer (cinnamon color) that I bought 3-11-10 on QVC. About 1 months ago it started shuting off after filling one cup of coffee, it fills the same amount of coffee no...
sdfdf
sfsd
fsdf
ds
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
It is not brewing the entire size specified.
Dec 22, 2010 | Keurig Platinum B70 Coffee Maker
The machine seems to be taking water from resevoir and heating and all but does not send it through the cup or anything and will not brew a full cup. I cleaned the needle out with a thin wire but that...
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
sdfsfs
Dec 18, 2010 | Keurig Platinum B70 Coffee Maker
Thin stream of water, only does a partial cup
weqwqwqw5555
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Coffee tastes like rubber / plastic - brand new Keurig Platinum - any suggestions?
After getting in touch with the Keurig folks - I tried their solution. And... it worked! The coffee this morning tastes wonderful! Here is what they said:
To get rid of the "new brewer taste", we recommend you flush three reservoirs of water through the system. Please add 2 tablespoons of white vinegar to the first reservoir of water. To do this, follow these simple steps:
~ Open and close the handle to simulate a brew cycle (without a K-Cup)
~ Press the largest cup size and brew a cup of water.
~ Repeat the process (opening and closing the lid, then brewing) until the reservoir is empty.
~ Flush two more reservoirs of water through the brewer in the same way.
This process will clear any lingering odors or flavors and allow you to enjoy an unadulterated cup of coffee.
Aug 19, 2009 | Keurig B70 Coffee Maker
Keurig B70 Coffee Maker Logo
3,025 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
