Question about Sanyo AVM-3259S TV
Remote won't turn on tv
Our tv won't turn off or on with the remote anymore. It is the remote that came with the direct tv. The remote works with the direct tv box if we go through the dvd player. Also we got another tv and the remote doesn't work either. You can turn both tv's on manually and everything if fine. We replaced the batteries on the remotes. Is there a fuse or something on the t.v that controls the remote?
  • Anonymous Nov 27, 2007
    oneforall remote stopped turning on my tv. How should I re-do the program to turn on my tv? I have changed the batteries on the remote, but I do not remember how to program my tv. I have lost the oneforall manual.
    Genius:
  • 1,074 Answers
No, there is no fuse on the television that control the remote, there is a component that they call IF means infrared.its a circuit that recieved the signal from the remote,amplify them and convert them to signals then decoded by the system control.if the remote is not working with the two tv then the IF circuit needs to be repaired.since you say that the remote works with the direct tv box.then i could assume that the remote is working.it could also be that the remote is not compatible with the tvs.try getting the the right remotes for the tv and see what happens.if it does not turn the tv on then we safely say it is the IF circuit.then you will have to take your set to a repair tech for repairs.good luck.
Posted on Mar 24, 2007
How do i restore my signal for Direct TV?
I understand the problem you have is the remote not controlling the TV?
If so, set the remote to TV and hit a button. it should ask you Manufacture and give a list of codes. If this does not work, go to Directv.com and look up how ton program remote. Directions should be there. Or just google the question.
Sep 02, 2014 | Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
We purchased a 32 inch tv from WalMart and I'm tring to program my remote to it but in the categories of tv selections it doesnt have the ilo brand name so I don't know how to set up the remote. Please...
I had the same problem with my ILO tv, I found a code for Funai- manufactured by the same company. Unfortunatly I don't know the codes anymore, but I hope it helps.
Jan 26, 2011 | iLO IWT3206 TV
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
DIRECT TV REMOTE WON"T WORK WITH MY RCA 32in LCD
if you want to use a single remote, try buying a learning remote
Aug 13, 2009 | iLO 3200 32 in. LCD Television
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Sanyo AVM-3259S TV Logo
621 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
