Question about SanDisk Sansa Clip MP3 Player
I use my sansa clip for audio books.
I would turn it off and when I restart it the audiobook would be in the same place. Now it goes back to the beginning of the download and I have to fast forward to get to the part that I was listening to.
  • 8,596 Answers
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
I recently purchased a Sansa Clip MP3. I downloaded audiobooks to it but they will not play. What do I need to do?
Not true!!! The Sansa Clip is actually the best mp3 player I have found for listing to audiobooks. Here is what you need to do. Download the latest firmware update on the Sandisk website. You must do this or it just won't work unless you are downloading books from Audible.
I use the Overdrive Media Console and download mp3 and WMA books from my state library. When you hit transfer, be sure it hit advanced options. Browse until you select the audiobook folder on your player. Then transfer to that.
The player will bookmark your last place on anything that is in your audiobook folder. You can easily switch back and forth between your music and book without losing your place! Love it!
It even has a sleep timer on it. I'm in heaven.
Apr 27, 2010 | SanDisk Sansa Clip MP3 Player
How do I move my audio books from the music folder to the audiobook folder
Hi There..
Please follow the steps..
1. Connect the player to the PC.
2. Copy the Audiobook files from the music folder to the folder named Audiobooks.
3. Disconnect the player.
Feb 05, 2010 | SanDisk Sansa Clip MP3 Player
Won't load audiobook because clock is not set
Had the same problem - used this solution from ehow.com at this web address: http://www.ehow.com/how_5180421_troubleshoot-sansa-clip-mp.html Worked and now I'm transferring my book from overdrive - hope it helps. Reset the Clip by holding the On/Off switch in the On position for approximately 20 seconds. Release the switch, then attach it to the USB adapter to charge it. This process can help when the Clip does not appear to be working at all.
Dec 16, 2009 | SanDisk Sansa Clip MP3 Player
Transfer error 0X8004C01A--Just started--What to do?
Some audiobook services have fixed-term licenses of 1-year - at the end of the time period, you have to resynchronize the audiobook files to the audiobook service itself.
Here is an interesting clip from the Sandisk forums on this exact issue:
Overdrive library books have DRM-encryption to make them stop working at the end of the loan-out period unless you renew them. This means your player must be set to MTP mode.
If your player intentionally or un-intentionally got switched to MSC mode, that would prevent the DRM content from being loaded onto your player and account for the error message.
Check it in SETTINGS > USB MODE on your player."
-Tha Mp3 Doctor
Feb 03, 2009 | SanDisk Sansa e270 MP3 Player
Audio book not going into audiobook section on sansa clip
There are two ways to delete files on your Sansa player.  You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device
For View, Fuze, Clip, e200v2, and c200v2 only
1. In playback mode, press the Submenu button.
2. Select Delete
METHOD 2 - Delete files using a PC
For all other Sansa players:
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't transfer Audible files to my Sansa Clip
The link to the operating manual (which includes the Audiobook instructions) is here:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
What I would do is drag and drop the Audible files from the folder that Audible creates to store your audiobooks to the Audible folder of the Sansa Clip, instead of using the Audible Manager.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Loading audio books onto sansa fuse clip 2gb mp3 player
You need to tag the .mp3 so it has a genre of "Audiobook". Google "mp3 tagger" and you'll find utils to do this for you.
Dec 19, 2008 | SanDisk Sansa e260 MP3 Player
Can not play audible book
Go into the Music submenu, and then keep pressing the downward part of the wheel until the "Audiobooks" option comes up. If you don't have any audiobooks loaded, then it MIGHT be greyed out (then again, I have no audiobooks on my player and I still have the option). The manual has the correct instructions, it just doesn't include pictures.
Jun 12, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip Audiobook Question
Once I downloaded the newest firmware the audiobooks folder started showing up in the windows file explorer. So now I don't have to worry about using media player or anything else. I just plug in my sansa clip, open windows file explorer and drag the folders (1 for each disk) onto my player (into the audiobooks folder).
Here's the link for the download. If it doesn't come up you might want to reformat your sansa clip.
http://www.sansa.com/support/sansa_clip/faqs
Dec 30, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
123 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
