Question about Dell Axim X51v Pocket PC
Dell Axim x51v that will not power on.
One day it was working fine and now I cannot get any lights on. I checked the battery and it's has plenty of power. I haven't checked the charger. I think it just died. Should I even try to get it fixed? This has been a bit of a lemon from the start. No wonder Dell no longer supports it!
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Posted on Jan 16, 2009
I have a similar problem, where the unit will not power up. I found it to be the back cover interlock. The little latches on the back cover has to press down on the interlock for the unit to power up. I added a small piece of tape to increase the pressure on the interlock, sort of iffy, but it worked on my pda. But this wouldn't work with the extended battery.
Posted on Mar 13, 2009
No power
Posted on Jun 27, 2011
I have installed a 8GB SD card in my Axim X5, but cannot seem to access it. Does it need to be formatted, and if so, how?
Posted on Jun 29, 2010
HELLO , My dell axim x51v is working by charger without the battery . But with battery is not working and not charging .
Posted on Apr 21, 2009
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
I have a dell axim x51v, I does not stay operational
seems to be some problem with the battery itself. Try charging it fully and then check. Does the battery dip when the phone turns off?
Jul 08, 2009 | Dell Axim X51v Pocket PC
Battery ramdomly goes dead after super heating
You may want to look at updating the ROM. There may be a fix in a later version of the ROM
Nov 11, 2008 | Dell Axim X51v Pocket PC
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Dell axim 51v
I have the same problem. Its from an over sensitive switch. You arent actually opening the battery case you are pressing against it. This triggers the switch and makes it think you are taking the battery latch off. I haven't actually tried it but you could open up the Axim and cut the cable going to that sensor/switch?
Mar 06, 2008 | Dell Axim X51v Pocket PC
Dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here : http://www.microsoft.com/windowsmobile/activesync/default.mspx
Aug 05, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51V
I have the same problem. I've found that the Innopocket magnum case will hold the cover in place and pretty much stop it doing this. Unfortunately, the case won't fit if you have an extended battery. I've tried taping down the cover with some success, but the hard case worked better.
Jan 25, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC Logo
2,309 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
