Question about Aiwa HP-A091 Consumer Headphones
Aiwa cxzr525 cd component does not work.
Tuner, turntable, cassette, speakers all good. cd drawer opens. cd drawer closes when cd is inserted. 5 cd tray turns around stopping on each number. cd tray stops without playing any cd. as if no cd is on the tray. for a while the cd cleaner test cd did play. now not even this plays.
egadgetguy
  • 263 Answers
SOURCE: I have an Aiwa digital
Hi
  1. The door is either busted, or the lock is.
  2. The tray is off it's guides or the belt or gears are messed up
Hope this helps.
Ken
Posted on Aug 14, 2008
  • 63 Answers
SOURCE: Have Aiwa NSX-V9090 Stereo with jammed cassette. I
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Posted on Aug 19, 2009
  • 6 Answers
SOURCE: Aiwa cd player model CXZR525U loads the cd's and
Try using a lens cleaner to clean the lens it is likely that the player cannot read the disc after it spins it.
Posted on Oct 07, 2009
  • 4234 Answers
SOURCE: Aiwa cxzr525 cd player. After loading under the
The clicking you are hearing is an attempt to focus on the disc. The usual cleaning discs don't work well. Try to gain access to the lens and clean itusing a cotton swab and alcohol. That will remove any film that remains on the lens. If that fails to resolve the problem, the optics will need to be replaced.
Dan
Posted on Oct 21, 2009
Testimonial: "Hello Guru, You were extremely helpful.After wasting my money on a disk cleaner which did nothing,the alcohol with a swab fixed my problem.Thank you!"
jobsagoodun
  • 156 Answers
SOURCE: Copied CDs won't play with my Aiwa LCX 350 shelf system
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
OR:
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
Posted on May 26, 2010
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
How to operate remote for AIWA NSC.5333
To check for a properly working remote do the following:
Get an AM radio and tune it to around 600 on the dial. Then take the suspect remote and push each button. Every button that works will result in a beeping sound coming from the radio - you can even fine tune the radio for loudest beep. This will identify all working and non working buttons. For non working buttons open remote and clean contacts on board and buttons with swab moistened in alcohol. Or try rubbing pencil graphite on the board contacts and bottom of remote buttons. Sometimes a small piece of aluminum foil inserted into the remote button depression will do the trick. Good luck!
Feb 23, 2014 | Aiwa Televison & Video
We have lost our manual to AIWA CD 5 /Z-R 900/. Could we download a manual or have one sent per e mail?or post? kotulovci@gmail.com Kotula Rudolf Mudronova 41, 81101 Bratislava Slowakia thank you
There could be many issues with your cassette. When you put the tape in and press play, due you hear a mechanism turning and the heads move up into the tape cassette? Parts and service information, are long discontinued for Aiwa, as they are out of business. Please visit my website at audioserviceclinic.com for more information. Thank you.
Nov 10, 2013 | Aiwa Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
3-cd drawer opened (aiwa cx na 777) and my brand new Iron Maiden CD dropped inside of the unit below the disc spin device (motor shaft and hub?), now I'm afraid to close the drawer. I want to take it apart...
Hello
You have to open the unit to take the CD out of it. If you can, do this. If you are not able to doe this work, contact the nearest authorsed service center for Aiwa at your town. Aiwa is not a brand in market now, as Sony Corporation has purchased Aiwa. so it will be best to contact the Sony Authorised Service center at your town. OK.
Sep 01, 2010 | Aiwa NSX-A777 Shelf System
I turned my TEAC GF450K7 on and then I get an error code 04. The cassette / phono and radio work fine. However, CD drawer is not opening...any solutions would be very much appreciated!
Where you able to find a solution for this problem? I just turned my GF450K7 on and got the error code 04. CD drawer is not opening. Let me know if you found a solution. thanks! :)
May 24, 2010 | Teac GF450K7 Turntable
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Jul 16, 2007 | Teac GF-650 Turntable
Open Questions:
Aiwa HP-A091 Consumer Headphones Logo
91 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
