Question about Yamaha YSP1000 Main / Stereo Speaker
YAMAHA YSP 1100 - ERROR-7 - NO SOUND
I am unable to do auto set up for YAMAHA YSP 1100 sound projector. It says error E-7. Tried to repeat auto set up several times, but the error message is coming and the volume is blinking on the panel.Subwoofer value is 00db and I cant change it.I think subwoofer is the reason for error.Manuel set up works but it doesnt help.LFE is set -20 to 0 .Factory reset wont solve the problem,too.What else I can do.please guide me.
  • 1 more comment
  • imparator Dec 15, 2008
    thanks for trying but I have already tried to reboot and checked cables.Still having the same problem.
    I am unable to do auto set up for YAMAHA YSP 1100 sound projector. It says error E-7. Tried to repeat auto set up several times, but the error message is coming and the volume is blinking on the panel.Subwoofer value is 00db and I cant change it.I think subwoofer is the reason for error.Manuel set up works but it doesnt help.LFE is set -20 to 0 .Factory reset wont solve the problem,too.I have already tried to reboot but still having the problem.What else I can do.please guide me.
    I dont think I could solve it myself, better I take it to the service which will cost me a lot.Thanks for your help.happy holidays to you ,too.
    President:
  • 2,110 Answers
Http://www.yamaha-uk.com/pdf/owner_manuals/YSP-1100.pdf
try to follow troubleshooting part of this document...
Posted on Dec 15, 2008
    Master:
  • 479 Answers
This unit fails to turn on when STANDBY/ON is pressed, or enters the standby mode soon after the power has been turned on. The power supply cable is not firmly connected to the AC wall outlet or to the AC inlet on the rear panel of this unit. Connect the power supply cable firmly to the AC wall outlet or to the AC inlet on the rear panel of this unit. 23 This unit has been exposed to a strong external electric shock (such as lightning and strong static electricity).
check out trouble shooting option in the above link for complete help on page number 90 http://www.yamaha-uk.com/pdf/owner_manuals/YSP-1100.pdf
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, error "E-7" refers to an "internal fault". Try a hard reset by unplugging from the mains for an extended period of time and thereafter repeat the auto setup procedures. If this is not corrective, then internal diagnosis is needed. This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
If the unit is still under warranty, it maybe to your advantage to require manufacturer's service or a replacement.
Good luck and Thank you for using FixYa. Happy Holidays.
    Sergeant:
  • 229 Answers
Make sure that you antannae is attatched correctly auto setup need a strong signal strength to work properly. Also do a hard reboot by unplugging the device for 10 min or so and then reattempt. Hope this helps!
I AM LOOKING FOR A REMOTE YAMAHA SOUNDBAR YSP-1100
The replacement remote is available at Amazon.com and probably other vendors of replacement remote controls. The replacement original remote at Amazon is here: https://www.amazon.com/OEM-Yamaha-Remote-Control-YSP-1100SL/dp/B0166DUFAE . If you need the information to program this remote for other devices, see the manual. The manual is available from Yamaha at the product support page: http://usa.yamaha.com/products/audio-visual/digital-sound-projector/ysp-1100_black__u/ . The direct link to the manual is currentlyhttp://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=8872 .
I hope this helps.
Nov 24, 2016 | Audio Players & Recorders
Power became intermitentnow no power whatsoever changed the plug/fuse but no joy any suggestions
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
Replace with a 22nf capacitor - Maplin part number N38CN -
the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
Jan 18, 2010 | Yamaha YSP-1100 Digital Sound Projector...
My ysp 1100 stopped turning on
Oct 13, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Hi, our ysp 1100 projector won't turn on anymore, no power seems to get through, where can i take it to for repairs i live in Nsw Australia , we bought it from domain erina.
Replace with a 22nf capacitor - Maplin was part number N38CN
Jul 07, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Ysp-1100 clicks when power is pressed but does not turn on.
Sounds like a a pcb dry joint or a poor connection on a multiway plug / socket.
try removing and refitting all the pcb plugs - better still spray carefully with WD40
Goog luck, Gaz
Jun 21, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Connecting an iPod to Yamaha YSP-1000
The best way to get quality sound would be to go through the USB connection of the phone.
It will be hard and a bit costly to get a cable to link the Ipod and projector.
Easiet and economical way is to go to apple and purchase a cable for the jaudio jack at the top of the Ipod that will also have an audio jack connector for the projector
May 31, 2009 | Yamaha YSP-1000 Main / Stereo Speaker
Power Subwoofer doesn't work
Two possibilities:
1. Your source material does not contain bass frequencies.
2. Your SUBWOOFER SET - BASS OUT is set to Front, rather than SWFR (subwoofer). See page 63 of the manual.
https://www.yousendit.com/download/dVlvdFdaY3lJMHZIRGc9PQ
or
http://tinyurl.com/csw8sy
Let me know if that helps.
Apr 19, 2009 | Yamaha YSP-900
Yamaha YSP 1100 clicks when press power button but does not turn.
Hi
I have the YSP1000 and I had a similar issue but it was less frequent. I located the clicking sound which turned out to be a relay on the main circuit board. Before replacing it I removed the relay cover and cleaned the contacts. It has not miss behaved since and that was some 8 months ago. Give it a wizz
Mike
Apr 13, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Do I set my DVD output into the 1100 on Bitstream or PCM ?
If you truly have a blu-ray player, it will have a HDMI port.
Feb 01, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Yamaha YSP1000 Main / Stereo Speaker Logo
123 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
