Wont power up
Emachine t3985 my fathers said he came into the room the computer was off
power on the monitor on "no video" cable modem all lights on everything else powres up but nothing when you hit the power button.brought it to me .i plugged it in no power from the button .opened it .has the green board power on.nothing burnt or out place cleared the cmos .changed cmos battery
unplugged all components. pulled the front checked the switch .has power from the supply to board .even the power led onto the swich legs and led lites up so theres power to the switch .just nothing initializes.no fan .no beeps no nothing.pulled the memory ,the processor .nothing appeared even offf color
put a new power supply same led on board but no power .i know all the boards that made in the last 5 years all have the safety switch built into the fan leg for the cpu.if you have a fan with a bad sensor or use a fan without one (2 wire instead of 3) your board will not power up .usually youcould hold the insert key while powering to get back the default but i get nothing.....................anyone on the geek squad here got any suggestions?...new fishing lure?..new bottom weights for ling cod fishing ?
or is there anything that can be done...help please
    Scholar:
  • 86 Answers
If you are getting absolutely nothing, and it seems you have checked all the obvious, then I guess its just the board given up
Posted on Dec 15, 2008
What cords are needed to connect my emachines windows 7 desktop computer?
  1. CPU Power Cord
  2. Monitor Power Cord
  3. Monitor video cable
  4. Mouse w/cable (unless wireless)
  5. Keyboard with cable (unless wireless)
  6. Network cable with 8P8C connectors (unless wireless)
  7. Speaker audio cable (unless internal or no speakers)
  8. Speaker power cable (unless CPU powered or no speakers)
Oct 22, 2015 | eMachines Computers & Internet
Why will emachine 1358g not boot up monitor goes to sleep just after powering up?
There is no video output from your computer, that is why the monitor goes to sleep, check the cable and the video card.
Sep 03, 2014 | eMachines Computers & Internet
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachine w3653 wont power on, no fan or lights
Check the power cable or check the SMPS (Power Supply) of your system.
Jan 09, 2013 | eMachines W3653 - 24084
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Computer start but wont Boot up.
Here are a couple steps you can do to verify something didn't come on correctly.
- Verify the monitor cable is connected tightly to the monitor and PC.
- Verify the power cable is plugged in.
If both of these check out is there a little LED light on your monitor that is on?
If not swap it out with another monitor and see if a different one works. If so we have a bad monitor.
If both do not work you may have a video card issue. Most EMachines come with a onboard video card which is bad news. If you have a onboard video card you will have to verify the warrantly though Emachine and get it fixed. Good luck and I hope things go well.
May 02, 2009 | eMachines W3623 PC Desktop
Emachine shut down
No, it's just the USB ports that are still being powered.
Totally normal in most new computers. Same thing with the PS2 ports.
There are jumpers on the motherboard that can change this if you really want. It's designed like that to keep things like you have powered for when you do turn it on and need them.
Apr 16, 2008 | E-Machines eMachines Desktop PC
EMachine monitor quit
This could be one of three components:
1. The video card
2. Video Cable (cable from the monitor to the computer)
3. The Monitor
The way I would determine this is:
I would try to plug this monitor into another computer that you know works with other monitor. If this is a home computer and you don't have another computer to test this take it to a friends house. Use a different cable to connect the to computer and power if possible. Then switch out to the old hardware (e.g. power cable, video cable.) If all has been determined to work then it's probably the video card.
If you can do this at all I would suggest trying a new video cable they are cheap. Usually 10 bucks at the most or borrow on from someone else. If this is a DVI cable they are a little more expensive. VGA cables look like this btw http://www.networktechinc.com/cable-pc.html
Dec 08, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Computers & Internet Logo
176 people viewed this question
Alun Cox
David Payne
David Payne
