Question about Panasonic PT-47WX42 47" Rear Projection Television
TV shuts off after 15mins or so.
The tv shuts off after some time has gone by but if you take the back off and put a fan back there it will stay on forever. Can you please help i think its a fan problem but dont know how to find it if thats the case. Thanks Jeremy.
  • 10,594 Answers
Some output chip is getting over heat in TV and goes to TV shut off mode, it calls protection.
Let me know model number to help you better.
Posted on Dec 15, 2008
  • 492 Answers
My suggetstion would be to keep a small fan cooling the unit.  It is obviously having heat issues I am sure that you could gather.  But weather it is one part or another is impossible to tell.  Most times they will just replace heat related boards.  Depends on how far and how much you are willing to spend.
    Master:
  • 479 Answers
Check out the motor which moves the fan that might have become weak .
Replaced lamp on Sony KDS50A2000 and now it shuts off and on every couple of minutes. I used the Menu-Settings-Lamp command and no change. The green light stays on and the sound is also still on. The lamp...
Your tvs lamp is getting over heated. There will be a fan for colling the lamp. if the fan doesn't work properly the lamp will get over heated and the will switch off itself to avoid further damages. Do one thing, Remove the fan from the tv. In the fan there will be a specification sticker. Remove the sicker. Now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. You can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the tv. power ON the tv and watch. If the fan is available then try to replace the same. it will not cost a lot. just watch the following video for oiling the fan. its for a PC fan same for all dc fans.
ok
Apr 01, 2011 | Sony KDS-50A2000 50" HDTV
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART
Jan 26, 2011 | Sony Televison & Video
I turn the Tv on and after 2 or 3 minutes the tv turn off and the blue light stay on and the red light start blinking
Most likely the fan in the rear has gone bad and the lamp is overheating and the system identifies this and shuts it down. Check to see if cooling fan is activating on power up.
Jan 12, 2011 | JVC AV-48P775 48" HDTV
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV shuts off and then back on, power indicator stays on steady.
I JUST (2 minutes ago!) had the repair man leave for the EXACT same problem on the same model TV!! All he had to do was take the front panel off the TV (in the front) and clean the bulb and fan. He said that the dust gets trapped in there and makes the bulb power off! $100 service call to clean the bulb!! Now it is working GREAT and has not powered off since! Hope this helps!!
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
