Question about Nikon N50 35mm SLR Camera
Err message Hi, I am getting an ERR message after I take a picture. In addition, at times the flash symbol apprears on my LCD screen, even though the flash is on. The lens seems to focus ok, and makes no unusual sounds. The ERR message flashes for about 10 seconds, and then goes away until I take another picture. I have the manual, and have tried without success to figure out the problem myself. Thank you Jessica Gerber
2 Suggested Answers
devocap
  • 201 Answers
SOURCE: error message
Hey there deliafuentes, I would suggest you check your film to ensure it is seated correctly and fed across to the orange line inside the winding post on the right side of the open back of the camera. If this is not the problem, I would check the settings to ensure you are not in a protection mode which will prevent you from snapping a picture which is not properly focused or without the necessary light required. Try turning off the auto features to test the possibility. Another option is the batteries may have insuffient power to drive the features which you are using. Switch to a new set, preferrably not rechargeable or generic. Good Luck!
Posted on Jan 28, 2008
Flashing message symbol at top of screen says SIM memory full is this right, but ive tried different sim cards that are empty how can i get the flashing message off
To get rid of this flashing message symbol please delete the sim messgaes.
To delete the sim messgaes follow the steps,
Menu--->Messages--->Options---->Sim messgaes
open it and you can delete the sim messages.
You wont get the flashing message symbol
Thanx
Jul 23, 2010 | Nokia 5800 XpressMusic Smartphone
Fuji s1, when I power up I get "Err" message on top LCD screen. Batteries are all freshly new.
"Err" message relates to the batteries.
If constantly lit, It's the AA batteries. When flashing, it's the lithium batteries. It can also be the tiny switch in the media door. Try activating it gently with a pointy object to see if the message disappears.
Dec 05, 2009 | Fuji FinePix S1 Pro Digital Camera
Won't take picture though I replaced battery.
Even though it was cushioned somewhat the camera took enough damage to jam something. The flashing symbols are a generic error code it could mean the shutter, zoom, film transport, flash, or some combination of these system are not working (sorry but without tearing the camera apart I can't narrow the problem any further)
Nov 05, 2008 | Minolta Freedom Action Zoom 90 35mm Point...
Err min Message
This can happen if you are using a non-G lens, without the lens aperture being set to the minimum aperture and locked.
Sep 09, 2008 | Nikon N50 35mm SLR Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Error message
Jan 28, 2008 | Nikon N50 35mm SLR Camera
Flash not working...
I have a DSC-W80 CyberShot I had a problem with the error code on the LCD Screen that said E:91:01. I played with the camera for a little bit and found the if you push the home button and go to settings. When you get to the settings go to main settings, When you get there go to initalize and follow the instructions. MAKE SURE YOU SAVE YOUR PICTURES OR TAKE THE MEMORY CARD OUT OR YOU WILL LOSE ALL THE PICTURES. I hope this will help you.
Jan 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
MY N50 CAMERA IS FLASHING ERR
yes in order to fix this camera you need to replace the film transpot unit assembly and re-adjuster youre camera to factory ****. MIKE REPAIR TEC.
Oct 27, 2007 | Nikon N50 35mm SLR Camera
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Nikon N50 35mm SLR Camera Logo
337 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
