Question about Aiwa HP-A091 Consumer Headphones
Dear sirs: i have had the aiwa cxzr525 for several years. the first year i had it, the cd player stopped working after an extremely short time and i had it fixed under warrantee. a very short while after that it stopped working again. this was a few days or weeks post warrantee and i did not fix it at that time. the turntable, tuner and cassette player work just fine. for a while the cd cleaner also worked when i played it but now not even that works. the cd goes in and the five cd dish circles around and then stops and does not pick up any cd. clearly there is a defect somewhere. i decided to research this and have found that others have had a similar problem with the cd component. can you please help me with this? i would like to be able to trust aiwa products in the future. since others have have had the same problems perhaps you have a solution at this point.
  • 65 Answers
SOURCE: cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Posted on Sep 17, 2007
  • 4234 Answers
SOURCE: I own an AIWA Stereo Synthesizer Tuner which has a
Unfortunately without seeing the actual needle or cartridge, it is just about impossible to provide you with a part number. Where are you located? Needles are still available and I sell them all the time. I will try to locate the "standard" part number for your model, but there were often different setups available. Is there any way to provide a photo of the one you have now?
Check the balance of the tonearm as well. If there is not sufficient pressure on the needle, it won't track the record correctly either. Please note, the you shouldn't put too much pressure or you will wear the record.
Please keep us posted.
Thanks,
Dan
Posted on Sep 22, 2009
  • 6 Answers
SOURCE: Aiwa cd player model CXZR525U loads the cd's and
Try using a lens cleaner to clean the lens it is likely that the player cannot read the disc after it spins it.
Posted on Oct 07, 2009
  • 4234 Answers
SOURCE: Aiwa cxzr525 cd player. After loading under the
The clicking you are hearing is an attempt to focus on the disc. The usual cleaning discs don't work well. Try to gain access to the lens and clean itusing a cotton swab and alcohol. That will remove any film that remains on the lens. If that fails to resolve the problem, the optics will need to be replaced.
Dan
Posted on Oct 21, 2009
Testimonial: "Hello Guru, You were extremely helpful.After wasting my money on a disk cleaner which did nothing,the alcohol with a swab fixed my problem.Thank you!"
Grubhead
  • 5658 Answers
SOURCE: The right side of my aiwa hp-x222 headphone does
Check out my tip on repair of dodgy headphones.
Posted on May 04, 2010
My Aiwa CX-NAJ80 system will not come off Standby.
Sorry but the control board is shot that's why there inexpensive to purchase they only last for 3 to 5 years
Mar 02, 2014 | Aiwa Audio Players & Recorders
Aiwa How To
You are in Personal Minidisc Players, you know.
If it is as old as I think it is, recycle it properly.
Oct 21, 2013 | Audio Players & Recorders
Aiwa cxzr525 cd player. After loading under the eye cd does not spin or play. It just clicks. I tried a cd cleaner disk and that did not work. Is it the same as a lens cleaner? What else can I try? Thank...
Dan
Oct 21, 2009 | Aiwa Audio Players & Recorders
I have two aiwa nsx-d737 stereos with basically the same problem. On the one, the CD tray will not oepen and the display shows that it is playing a CD when it's not. On the second one, the CD tray will...
Hallo! Mayby you can sell my one of your aiwa nsx-d737 stereos? I've been dreaming to get it for a long time, but I can't find it nowere in Russia. I ready to pay all transportation costs and expances. May I also ask you to write me back on e-mail zhivulko@gmail.com even if you can"t or do not want to sell it?
A milliomn thanks))) Olga
Jul 13, 2009 | Aiwa Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
CD's sound awful
Try cleaning the lens with a CD lens cleaner. If that doesn't work, the optical pickup may be back. If tht is the case, it can be repaired but it will probably cost quite a bit (more than $100) to repair.
Dec 17, 2007 | Aiwa XR-M131 Shelf System
Aiwa Stereo System NSX-F9
insert CD lens cleaner first, then try to load audio CD if do not work change the lens
Nov 24, 2007 | Audio Players & Recorders
CD's NOT PLAYING
How often was the player used? Four years is a typical lifespan of a cheap CD player section if it sees constant use, and on this specific model i ran across a few cases in which the system died after a few months, and it makes you wonder why the warranty is only for 90 days(the ones i saw)... First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. It would involve taking the cover off and finding a way to take a slightly damped swab and gently rub the objective lens on the pickup clean, followed by a drying with the dry side. But, unless the player is prone to dust accumulation (which was a big problem with quite a few Aiwa shelf systems with the 3 disc changers), cleaning it may not help. Another possibility could be that the transmission ribbon which connects the pickup to the player electronics may have developed breaks, which is another typical problem with many shelf systems. Yet another possibility, which is the worst case: the pickup may have worn out. Again, if the player is four years old and was used constantly, it is very possible that the pickup has decided to give up the ghost. Another possibility, which is EXTREME worst case and is not likely to happen at any time with any CD player is a failure of the CD decoder chip. The decoder chip handles the 8-14 demodulation and error correction of the CD signal and outputs the processed signal as PCM for upsampling and conversion. If this chip fails, the CD player will spin up and synch to the disc but, without decoding, the player will be unable to read the TOC and play the disc. But, as I said before, this usually never happens as the semiconductor parts are the most reliable components in a CD player and usually never fail unless they were deliberately damaged by an external influence, like shorting out one or more leads with a screwdriver while the player is powered. In the latter three events, replacement parts may not be easily sourced, if at all, and the required labor to effect the repair may not be worth it. (In addition, a new pickup has a protective solder short designed to protect the laser pickup from static discharge damage. This short has to be desoldered in order to allow the pickup to function.) In this case, replacement of the entire shelf system becomes necessary. If buying a new shelf system, stick with some of the better brands in this area like JVC, Sony, Panasonic, Aiwa, Pioneer, and even Philips. Brands to avoid include Sharp, Sanyo/Fisher, RCA, Emerson, and any cheap store brands like Durabrand or CurtisMathes. But, in general, even the finest shelf systems are a compromise in design which can affect reliability. Most, even from the recommended brands, weren't designed to be serviced very easily when they break as people usually dispose of them rather than have them repaired.
Nov 15, 2005 | Emerson MS3105 CD Shelf System
Aiwa HP-A091 Consumer Headphones Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
