Question about Hammering
Serpentine belt came off
I have a 94 chrysler lebaron and my serpentine belt came off, how do i put it back on? I was looking for a diagram online, but i can't seem to find one, can you help me?
  • 1,498 Answers
Here's how to get a serpentine belt on or off (You'll need to do both). It's easy and doesn't require a prybar. The routing is usually diagrammed on a label under the hood.
On:
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • Locate the tensioner pulley. It's one of the smaller ones and is mounted on a spring loaded arm. It's job, as the name suggests, is to keep the belt tight. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Off:
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt off one of the pulley's (A/C or Alternator is best)
  • You're done
Mike
Posted on Aug 15, 2009
  • 368 Answers
Hi Kaede247,
I'm not aware of any online sources I can post without copyright infringement; realistically, you should invest the $20-$25 (typical) in a hardcopy manual for your vehicle that you can use while you're working on the car (thus avoiding greasy fingers on your computer keyboard or display). They are available at nearly any auto parts store.
There is typically a tensioner pulley of some kind you will need to loosen, slip the belt into position, and then re-tighten, preferably to factory-spcifications, but at the very least tight enough that you can't easily deflect the belt between two pulleys, and so it doesn't slip.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 16, 2009
The serpentine belt came off my 94 lebaron. i put the belt on and started the motor.the belt seems to be out of alignment on the power steering pump pulley. is there any way to adjust the pulley?
With the engine running very carefully place a screwdriver to the side of the belt that nedds to be put back on track. A slight push will move it over. Be very careful because slip could shoot the screwdriver out of your hand.
May 21, 2011 | 1994 Chrysler LeBaron
Diagram for timing marks 94 lebaron 3.0litre
Click on the following free, direct Link. It has all the Timing Belt Diagrams with Marks you will need for your 1994 Chrysler LeBaron 3.0L.
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1994/make/chrysler/model/lebaron/1994_chrysler_lebaron_timing_belt_diagram_marks.htm
Apr 05, 2010 | 1994 Chrysler LeBaron
Re install a serpentine belt on a 94 chrysler lebaron 3.0L
There should be a diagram attached to the car near where the belt goes showing how the belt is to run through the pulleys.
Newer vehicles have a tension pulley which is a pulley on a spring loaded arm that keeps the belt tight.
First run the belt on all the other pulleys and then use a wrench to hold the tension pulley back while you slip the belt on.
Older cars do not have a tension pulley and you had to usually loosen something like the alternator a little bit to get it on.
Mar 12, 2010 | 1994 Chrysler LeBaron
Serpentine belt diagram 1993 chrysler lebaron v6
To remove the serpentine belt from the 3.3L and 3.8L engines, rotate the tensioner assembly clockwise
Jan 10, 2010 | 1993 Chrysler Lebaron
Do you have a diagram on how to install a serpentine belt on a 1994 Chrysler LeBaron?
1994 CHRYSLER LEBARON - V6 3.0L 2972cc 181ci GAS FI N 3
Open the hood, the diagram for the serpentine belt is on the cowling.
From DAYCO Catalog
Belt Routing Diagram (Alt., P.S., Idler & Tens.)
From comments to other users and Lebaron Owners; for remove, starting at the alternator pulley and going clockwise around the pathof the belt, the belt drops down and forward and goes under the idlerpulley, continues forward and less steeply downward and goes around thecrankshaft pulley clockwise, rises rearward going over the top or thetensioner pulley counterclockwise, then drops down and around the powersteering pump clockwise and rises to go around the alternator pulleyclockise (which is where I started the description). To loosen thetension to remove the belt, or to give you slack to install the beltwithout having to force it over a pulley while under tension you rotatethe tensioner pulley arm around its pivot clockwise according to the'94 shop manual. It doesn't show by what means to effect this rotation,but in the earlier manual I have ('89) it shows there to be a 1/2"square hole in the tensioner arm into which you insert a breaker barwith a 1/2" square drive which gives you the temporary lever to rotatethe tensioner against its spring action. I assume there is a similar1/2" square hole on the '94 you are working with. Interestingly,between '89 and '94 the idler pulley was added, and the requiredrotation of the tension arm changed from counterclockwise to clockwiseto relieve the tension."
I think this will help you get the belt on. Good luck.
Oct 13, 2009 | 1994 Chrysler LeBaron
Where can i find a diagram to install serpentine
Most parts stores can print this out for you for free.
Sep 10, 2009 | 1991 Chrysler LeBaron
Need diagram to put serpentine belt on
did you look under the hood, there is a diagram there
Jul 13, 2009 | 1994 Chrysler LeBaron
How to put on Serpentine belt for 92 Chrysler Lebaron 3.o liter engine
Before replacing or installing the old belt you need to check all of the pulley's that the belt rides on for play. Pay special attention to the spring loaded tensioner pulley. They can sieze and cause the belt to come off.
I found this picture it is a bit large for the screen.
Aug 29, 2008 | 1995 Chrysler LeBaron
Need a belt diagram
Good Day,
One is with A/C the other w/o.
Hope this helps
Jul 08, 2008 | 1995 Chrysler LeBaron
Hammering Logo
216 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
