Question about Sanyo PLC-SW30 Multimedia Projector
Projector overheats after 30 minutes and shuts down
My porjector overheats and shuts down after 30 minutes of usage. I have to time my usage and unplug the projector too cool down before restarting.
  • queendacoe Dec 16, 2008
    Yes, the fan is still working in high speed.
    Thanks!
  • 43 Answers
Had the exact same problem, after my projector was powered off upruptly.
Turnedout all I had to do was push down slightly on the tempreturesensor/fuse (is opens the power circut if the projector gets too hot,and thus doesnt allow any current)
Here is the full repair/service schematic for the projector. It should help you locate the sensor.
Good luck
http://yama.co.za/forum/index.php?topic=146.0
Posted on Dec 03, 2009
Is the fan in your projector still working in high speed or not spining?
Posted on Dec 16, 2008
  • 2 more comments
  • smart nerd Dec 16, 2008
    Usually projector have like three to four different fans, there are two fans that you can see it and there are two more fans that you can't see it like near the lamp location. The fan usually increase their spinning speed according to how hot it gets. If that pass with out a problem, then you might have Thermistor failure that will cause the unit to trigger shut down after 30 minutes.
    If you have some test equipment like DMM, or VOM meters you can troubleshoot it yourself, but it involved with removing a lot of screws and more details on how to fix it correctly. I can teach you how to fix it in step by step if you want to learn it. But you need to make sure where to get replacement parts to get it to work correctly.
  • Abdulrahman Dola
    Abdulrahman Dola Jun 07, 2014
    mine is sanyo pro XtraX multiverse all the 3 fans are working but heats badly and turns off after 5mins
  • smart nerd Jun 08, 2014
    Sanyo Pro XtraX multiverse heats badly and turns off after 5 minutes. Have you tried to remove the dust from the fan and from the projector light area. Some projector also use filter where the fan is at. It might be clogged too.
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
I have a Sanyo PLC XU45 projector which recently gegan to shut down after about 10 secs after switch on countdown (30s). All Fans working OK. I've cleaned the filter (which was clogged). Funny thing, when...
How many hrs are on it? I suspect the lamp is going out of it... Buy another lamp and go from there. This way even if it isn't the lamp you will have one in stock. But if it is, you have just fixed your porjector.... Good luck..HDTV GURU JAY
Mar 18, 2011 | Sanyo PLC-XU45 LCD Projector
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
Shuts off after approximately 2 minutes
I have exact same problem. According to the manual its time to replace the bulb. But when I check the runtime on the bulb it shows 326 H. I am not certain if this is the remaing hours on the bulb or the usage to date hours.
I would appreciate anyone commenting and recommending a solution.
Jun 13, 2010 | Panasonic PT-AX100U-EC DLP Projector
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
Oct 04, 2008 | InFocus LP 600 Multimedia Projector
Projector restarts after 30 minutes or so
Hi jamble77
This sounds like a faulty Ballast ( lamp's powersupply ) if it made a grinding noise and now the Projector shuts on and off intermittently.
I would advise you to rather have the part replaced than repaired , as in most cases the Ballast almost always returns with the same problem if repaired a couple of months down the line.
May 20, 2008 | Panasonic PT-AE900U Multimedia Projector
Lamp Replacement
some projectors have a shut down timer. if it not being used for a specified amount of time, it'll go into a "sleep" mode to save the lamp. but the projector was designed for continual use. if the lamp get too hot, say after 12 hours, it'll go into thermal shutdown to cool off. turning it off when not in use saves the lamp a few hours or minute, but it's not necessary. just like keeping your car idle while you're in the house is ok, but it wastes gas and is not necessary.
Oct 18, 2007 | Eiki USHIO PROJECTOR LAMP, Projector Lamp...
Sanyo PLC-SW30 Multimedia Projector Logo
659 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
