Question about RCA HD61LPW42 61" Rear Projection HDTV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
About 3 weeks ago our HD61LPW42 began shutting itself off after the picture started flickering and losing primary colors. The TV had to be on for about 4-5 hours before the problem would occur; but it was 100% reproducible if the TV was left on long enough. RCA was called. A local tech came out and was puzzled at what would cause this. RCA techs recommended to local service that the main color board component be replaced. Two weeks later the part arrived, and it was installed. The problem now occurs after 15-20 minutes after the TV has been turned on. The TV is now completely useless to our family. RCA techs are at a loss for what might be causing this. They now want to take the TV back to the shop to work on it there. ETA: 3-4 weeks! I simply can't believe RCA hasn't seen something like this before. Unfortunately, so far, nobody seems to know what to replace next to fix it. Although these TVs are highly technical, they are componentized. Why is it such a mystery to replace components one by one to isolate the problem? If a picture can speak a thousand words... I've got video footage of the problem up on a web site. I won't post the URL here as I'm not sure if that is allowed, but it is available upon request.
  • Devon Hubbard Mar 22, 2007
    Thanks! That is very interesting to hear because one of the service men that came out one time commented that the familiar spinning [of the color wheel] was a little louder than usual on our TV. I commented that when the color on the TV starts going all goofy, you can hear the pitch of the color wheel changing if you're listening closely. After reading your reply, I'm convinced this is definitely not a coincidence.
    If you have any links to RCA service docs or info about color wheel bearing problems, please let me know. I'd love to find service documentation to back this up. Anything to help push RCA to a faster resolution.
    Thanks again for your opinion on the problem.
  • 103 Answers
The unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Posted on Mar 22, 2007
SOURCE:
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
BIG SCREEN TV WILL NOT COME ON
YOU LOST VERTICAL DEFLECTION THIS IS NOT HARD TO SOLVE
Dec 25, 2009 | Televison & Video
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Intermittent picture
Most likely your lamp needs to be replaced as that will cause the intr. picture issue. The color wheel will also have to be replaced. The color wheel is only available with the light engine which is part# 263223 and the lamp part #260962
Mar 05, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
232 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
