Question about Acer AL2016W 20" LCD Monitor
The monitor screen blank / black and power on off switch flashes
I use the monitor when in the office. I hook laptop up to port replicator . The screen remains blank yet the on off switch flashes green - so there is power to the unit
Appreciate your feedback as I really need this monitor
  • 585 Answers
You could check the VGA cable from the replicator to the monitor, but a problem with that will usually cause a "NO SIGNAL" message to appear. So your issue seems to lie within the monitor. It could be that the backlight has quit. That can be determined by booting the laptop and connecting it to the replicator, or perhaps to the monitor directly, and observe the screen using a good flashlight, place the flashlight flush on the screen in an area where you would expect to see an icon or some recognizable image. Look closely to see if the image can be seen. If the image is there, then the screen is ok but the backlight is out. The problem is usually the inverter. A reputable shop might be able to replace that.
Posted on Dec 15, 2008
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
My laptop is installed in my port replicator; I also have a Dell monitor plugged in to the port replicator. For some reason, after having to re-boot my computer, the output is appearing on my laptop screen...
Press Fn+F10 to toggle the display back and forth on the laptop screen and external monitor. Pressing the keys a third time would close the display on both displays. Thanks, Abhishek.
Mar 09, 2010 | Toshiba Advanced Port Replicator III...
The hp mx 705 monitor was working,then it just went blank and black. the power button light, just blinks green.
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
Nov 07, 2009 | HP mx705 17" CRT Monitor
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
Dual monitors: DVI and VGA not supported simultaneously
It looks like this a problem for the Port replicator III, not II, right? I'm not an expert on port replicators, but if you have even an ok video card, it should work fine even running all three...
Feb 03, 2009 | Toshiba Advanced Port Replicator III...
External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Samsung SyncMaster 191T
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Acer AL2016W 20" LCD Monitor Logo
171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
