Question about Aloha Housewares (93645) Ceiling Fan
Smoke care from the wiring between fan and light
My 52 inch fan has been installed and working fine for over a year when smoke began coming from the box between the light and the fan. I disconnected it and saw that the (plastic) capacitor was beginning to melt. I removed the capacitor and the nearby electrical supply store does not carry anything like it. Because the plastic has begun to melt I cannot read the identication on the capacitor except fot something that looks like: 3 @ FU; Red, Yellow and purple ; 250AC; /60HZ C+- 5% and max temp 70(degrees) C If you can direct me as to how I may buy a new capacitor will it be okay and safe to just repalce it and put the unit back together and try to run it again?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, to my understanding, you could get the capacitors from Aloha for free. 1-800-295-4448
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
    Master:
  • 479 Answers
Try radioshack website to buy this capacitors.just tell them proper model number of the fan and they will provide u with the capacitor.if they have it with them.
  • 19,396 Answers
Give me the eact model, I see if I can find replacement.
I have just installed a new receiver and remote in my 52 inch fan.tested it all worked. later that night my wife tried turning on the light and the remote came up with light symbol with a 100% behind it,...
Might need a new receiver.Did you hook up the receiver hot. If your fan came with pull chains,undo your light wire from the fan and wire nut it to house hot.This will tell you if your light is OK or if it is the receiver.
Feb 20, 2013 | Dryers
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Lights filicker on and off. Weather the fan is on or not. All wiring is good.
for the lights, open up, remove watt governor then rewire. should take care of flickering. but turn power off first ! after removing. hook white wire to white wire and black wire to red wire, this is the power or hot wire. it is a black box shape.
Apr 02, 2012 | Hampton Bay 52 In.Carriage House II in...
Our Hunter Fan and Light with remote has been installed for over 1 year. It has always had the 'ghost' problem where it will randomly turn itself on or off but we have been able to live with that. Last...
Your ghost problem was probably due to a loose connection. The wire has probably come completely loose or the heat from the loose connection has damaged the relay.
Jun 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Jul 29, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
How to install remote controller
I purchased this fan, however It didn't come with directions, could you please perhaps scan and email me a copy of yours?
May 02, 2009 | Dryers
After installation fan and light will not work
Did you make sure the wire nuts were tight in the fan and in the box? Is there a switch controlling this fan?
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Aloha Housewares (93645) Ceiling Fan Logo
71 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
